Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: My VN is chewing petrol like no tomorrow.
    90 vn wagz and 90 vn sedan
    Feb 2010
    Default My VN is chewing petrol like no tomorrow.
    It has a standard 40 or maybe 50ltr tank. Filled it up and petty was pretty much all gone in 2 days! Went through 3 quaters of a tank in that time just cruising around town. I checked for leaks none. It couldnt have been rauted since it was in the garage. So i have no clue why its going through so much petrol. Its starting to bother me filling the bastard up all the time! Any solutions?
    With great cars, comes great drivers.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Start making a record of kms traveled and how many litres used so you have some evidence of fuel usage.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Its a 63L tank, and "cruising around town" and "gone in 2 days" doesnt help us work out how bad your economy is....
    The Black Beauty
    Dec 2009
    How hard are you driving it you know are you flogging it at the lights or taking it easy? A VN should go at least 450 to 500km on a tank around town. If your not giving it a hard time I'd suggest trying a new oxygen sensor and/or engine ECU temp sensor.
    Can you remove the spark plugs and let us know what colour the centre electrode/insulator is?
    96 VS V6,98 VT 5.0 CLUBSPORT,VS V8 UTE 5 SPEED
    Feb 2008
    Brisbane Aus-loganlea
    1992 VP vacationer
    Nov 2009
    Quote Originally Posted by TVR-161 View Post
    does it really matter? If it bad, its bad.
    92 VP Series 2
    Jan 2009
    East Brisbane
    Yeah mate as already said we need a bit more info. Next time you fill up with petrol fill it up all the way to the top until the pump clicks, reset your tripmeter and then when you fill up again next time fill it all the way to the top again until the pump clicks, and take note of how many litres your car filled up and also how many kms its travelled since the last fill up. Here's a little calculation that will tell you the fuel economy your getting- say if you got 300 kms and used 45 litres of fuel, in your calculator write 100 divided by 300 and then multiply that by 45 and you'll get 15. That means your getting 15 litres per 100kms. As long as you fill up to the very top of your fuel tank each time this calculation should be pretty accurate. Also did this bad fuel economy just come out of nowhere or has it gradually been getting worse? And does the car feel at all like its lost any power? Any extra info you can tell us would help mate
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    you might need a good tune bro i think thats what the problem is a good tune and timing fix my commodore was doing the same till i serviced and tund it at ultra tune now she runs like heaven still drinks fuel but not as much as b4 prob every 3rd or 4th day refil considering i dont have a light foot on the accelerator
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
    Feb 2010
    The metre's arent working unfortunitly If someone can help me with details about fixing that i can see how many k's i get. I generally take it easy around. After all cops tend to target Commodore's and P Platers. Sorry im not the most knowleadgeable car person where will i find the sparkys? Yeah she's due for a service in the next 4000 clicks. So i might do that before tinkering around with things i have no clue about.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    follow the spark leads, its around the side of the engine, 3 on each side, therres leads connected to them, unplug them, get spark plug socket, and unscrw them, ifthe plugs are white thats running lean, brown, means just right, black, means rich
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    Dec 2009
    Take out the spark plugs an dif the centre electrode is eroded or covered in crap get some new ones then look at your air cleaner element if it's dirty go and get a new one, the gereric nes from super Cheap are fine. Then change your fuel filter. Refil it and check your economy if it has improved all well and good. If it hasn't go and buy an AC Delco Oxygen sensor and replace that the last one I got was about $50 from Holden. If that doesn't fix it then there is something more serious wrong with it like bad compression.
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    just do tha big um burn out m8.. pop the engine b4 the tyres and U the man... then fuel not tha problem; haha you get me. bury UR car and get 1 that workz
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Same issue with my VN, i usually get 300-50kms before the needle touchs empty but i think the sender is screwed because when i refil it only fills up say 40 litres.
    I've got a mate checking out my injectors as he reckons they are loose and i've got a feeling there is a bit of unburnt fuel going through the exhaust.
    Oxy has been replaced and the spark plugs are new NGK plugs. if your saying that your only filling up 40-50 litres it could be your sender.
    If anyone could confirm this it would be great as mine is due for a service..now/when i get the money.. Damn rego due
    Feb 2010
    Actually i just remembered the car is running on 5 cylinders. The fuel injector isnt working. Could that be another part to the problem? Mine also only fills it 40-50ltrs aswell. Needle has never touched "F" got as high as just over the line between Full and 3/4.
  15. #15
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Quote Originally Posted by havavb View Post
    Nah, can't think of any way a dead cylinder might affect your economy...
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  16. #16
    1992 VP vacationer
    Nov 2009
    lol
    The message you have entered is too short. Please lengthen your message to at least 10 characters.
  17. #17
    Feb 2010
    Well i filled her up half way, and gonna see how it goes. (How many days till i have to fill it again)
  18. #18
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    Ive gone from geting less than 350km per tank to over 400 by replacing my breather lines, fule pressure reg and O2 sensor.
  19. #19
    May 2010
    Croydon, Vic
    my cars currently showing 1/8th tank and i've only done 260kms.. this is on premium too.. havent driven like a hoon too much but a fair bit of stop starting.. wtf
  20. #20
    vs executive s2
    May 2010
    Default chewing fuel
    Are you sure its shifting into overdrive, s**t did VNs have overdrive.
    A few tanks of premium 95oct could help
    Cheers KB
  21. #21
    92 VP Series 2
    Jan 2009
    East Brisbane
    Quote Originally Posted by kbelt66 View Post
    Cheers KB
    Yeah mate vn's had overdrive, the vn transmission is basicly the same as your vs commy, just vn's weren't electronic and have a kickdown cable, where as vr and vs models dont have a kickdown cable
  22. #22
    Feb 2010
    Well ive cut down on my driving for now until i find more work. But last night however i did let it loose poppin' bangerz in front of a few people's house's who are going to be smashed. But i think i may add some premium in her today. Also, with driving. Which Drive is best to use? The standard 'D' or the 'D' with the square around it? Ive been using the standard one...
  23. #23
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    something wrong there lol . . i fueled my whole tank up in my vn, drove around hervey bay for half the day then drove home to yeppoon which is like 450km and i still had bit over quarter of a tank left
  24. #24
    92 VP Series 2
    Jan 2009
    East Brisbane
    hey mate it depends on how fast your driving. if your just cruising around town below 65-70 km/h then you can leave it in standard D, but over 70 you should put it up to the D with the square around it. i just leave mine on the D with the square all the time personally. if you have been driving alot over 70 km/h with it only in normal D than thats probably why your fuel consumption is shithouse, cos the normal D only lets the car shift up to 3rd gear, while the D with the square around it lets it shift to 4th.
  25. #25
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    the blue D is known as overdrive its like a extra gear and suitable for highway use, i still use it all the time where ever i go... occasionally i chuck it in the normal D
  1. chewing thru oil
    By ryan86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2010, 08:27 PM
  2. Tyre chewing problem solution
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 04:03 PM
  3. Chewing Out Rear Tyres
    By Brumbies 5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2006, 11:26 AM
  4. Series 1 VS chewing oil
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2005, 06:25 PM
  5. Chewing up fanbelts
    By Rickvsv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2005, 09:34 PM
