Has anyone put a vt fuel pump in a vp? Ive got a new vt pump here and the one in my wagon is on its way out i think. When it is under a 1/3 of a tank it cuts out going around right hand corners and roundabouts.
Matt.
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
Maybe have to adjust to fit? Im not a car expert but i dont think a VT fuel pump would just fit in. Maybe with tinkering..
With great cars, comes great drivers.
in physical size the vt pump is bigger, but it actually fits on the mount. The wiring connection is different but i can fix that.
Matt
- Lou Holtz
I dont see why it wouldnt work then, good luck mate!
you sure its the pump and not the pipe that goes into the swirl pot, seen a couple of the pipes corode and you loose 1/4 tank
No its not the pipe, i pulled the tank out to check this a few weeks ago. That was my first guess, also new fuel filter and i blew the fuel lines out with compressed air.
Matt
- Lou Holtz
