Results 1 to 3 of 3
Thread: Camshaft/ crankshaft timing position??
    UNLEASHED's Avatar
    UNLEASHED is offline Choose your weapon...
    A9G 5Speed/VXGen3wagz/Ducati
    Aug 2008
    Rannistan, SA
    Default Camshaft/ crankshaft timing position??
    Hey all. I think I put this in the wrong thread. What's the camshaft/crankshaft position in order to get the cam timing correct?
    I still have the origy in there but the keyway at 12:00 means the camshaft dot is either at 12:25 or 12:55??
    Found the rattle wasn't from the timing chain or the fact the tensioner had dropped into the sump, but Im doing the replacement anyway with a dual roller rollmaster and doing away with the tensioner and the balanceshaft gear...
    I reckon it's actually the belt tensioners lubrications dried up, causing the "rattle"
    UNLEASHED's Avatar
    Aug 2008
    Rannistan, SA
    All sorted, Hadn't opened the box yet.
    Destructions inside. Old gear position obsolete anyways...multi keyway crankshaft..
    Ashley- Formerly Nogen 3___________________________________________
    BAN LOW PERFORMANCE DRIVERS
    NOT HIGH PERFORMANCE CARS....
    Crush the hoons not the cars.
    UNLEASHED's Avatar
    Aug 2008
    Rannistan, SA
    All done. runs well. The noise was the tensioner- Could have sworn it was the chain tensioner dropped into the sump and the chain itself rattling. No damage on the inside of the timing cover. Balance shaft gone. balance shaft gear on camshaft gone to make way for the dual roller...
    Schweet!
    Please delete thread....
  1. Camshaft/ crankshaft timing position??
    By UNLEASHED in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2010, 02:38 PM
  2. Timing belt & camshaft oil seal replacement
    By grazm in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-10-2009, 09:05 PM
  3. F/S - ( Melb ) 308 / 253 hi-perf Camshaft/lifter/timing chain sets
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 26-04-2008, 09:23 AM
  4. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  5. Prob's with crankshaft/camshaft
    By Wolfass in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-09-2005, 12:44 PM
