Results 1 to 14 of 14
Thread: Leaking tail light/Boot.
    Vp S IRS 6 Banger
    Jul 2009
    Default Leaking tail light/Boot.
    G'day guys, Just took the bottom tail light globe out and water rushed outta the tail light. Is there a tail light seal or is it coming from the boot??
    Cheers,
    Daniel
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    The seals went on mine, silicon if you're cheap/lazy. Or replace through someone like this....
    eBay Australia Store: Search results for New Clear Lights.
    $72.60 for a pair, not too bad a price.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    1992 VP vacationer
    Nov 2009
    yeah after market light $hit all over genuine tail lights. they fix the common leakage areas with better plastic type and sealant.
    Dec 2009
    Just take the tail light out of the car and drill 3 holes about 3/16" to 1/4" accross the bottom to let the water out and all will be fine.
    Vp S IRS 6 Banger
    Jul 2009
    Quote Originally Posted by wortus View Post
    Cheers mate that sounds like the go.
    Dec 2009
    Quote Originally Posted by vps231 View Post
    No worries that's what I did with my VN to fix it and never any problem after that. Also if your getting water in your boot it will probably be the rear 1/4 windows and you'll need to remove them and reseal them with some windsscreen sealant.
    Vp S IRS 6 Banger
    Jul 2009
    The water in the boot seems to be coming from around the tail light area, Carpet gets wet around that area.
    Does it run down there from the 1/4 window?
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    ahh same issue as me lol... and yeh 3/4 window is a bitch but never repaired one so dont feel like touching it . . . car cover FTW lol
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Driling a hole or 2 in the bottom of the lens is a winner and cheap fix for rusting out the globe holders.
    To test the 1/4 windows - get a jug of water and run it over the roof so it runs down the getter over the 1/4 window. Have the boot open and look for water
    Water can also get in via the fuel cap cover seal.
    and 3 Dangerous non ABS VN's
    Dec 2009
    The carpet can get wet but usually it will collect water in the spare wheel. When I discovered mine leaked it was during a huge storm and the whole boot was like a swimming pool, nearly ran into the rest of the car.
    These side windows are just sealed with a bit of foam tape and a blob of sealant where that oins not very well done by Holden at all. There not hard to get out you have to remove all the inside trim around them and the back seat as well.
    Vp S IRS 6 Banger
    Jul 2009
    I think it was just leaking in through the tail light, well i hope so anyway.
    Dec 2009
    Just see how it goes next time it's outside in heavy rain. It may be worth checking to see if the lamp sockets in your tail light wiring harness are corroded from the water. It's common for this to happen and from memory a new one is not too expensive assuming they are still available from Holden.
    1992 vp calais
    Mar 2010
    i have a vp calais and have the same problem water leaking from the lhs taillight now a globe is blown and the spare tyre has i bit of rust on it i checked the seal and it looks good but i can see from the tailaight its moist on the inside of the tail light should i just replace it ? i sanded all the rust back to metal under the spare tyre came out a treat. is there anything i should spray to prevent the rust ?
    Dec 2009
    Quote Originally Posted by romez View Post
    I'd just take the tail light out and drill 3 x 3/16 or 1/4 inch holes in the bottom of it. In the spare wheel well I'd be painting it with some kill rust enamel and giving it a few days to go nie and hard. Put some foam rubber in to stop the tyre wearign it off and check for water every once in a while.
  1. [WA] WTB: VR VS Left hand boot/tail reverse light
    By Chirpstr in forum Swap / Wanted to Buy / Trade
    Last Post: 14-01-2009, 09:59 PM
  2. [WA] vb-h tail wagon tail light and bumper
    By markovr in forum Swap / Wanted to Buy / Trade
    Last Post: 19-12-2008, 08:20 AM
  3. WTB (VT/VX): rear bar, r/h tail light, garnish, repeater, reo, boot
    By SMIT in forum Swap / Wanted to Buy / Trade
    Last Post: 08-11-2007, 04:46 PM
  4. VS ute leaking tail lights
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2006, 11:21 AM
  5. Leaking Tail lights. Common Prob?
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 11:24 AM
