Results 1 to 4 of 4
Thread: squeeky annoying doors
    1992 vp calais
    Mar 2010
    Default squeeky annoying doors
    the doors on my vp calais squeek so i was told to spray wd40 on them it worked for like 1 day and now its frkn horribble any suggestions on what i can do
    when i had my vs and got it serviced at holden they put some white cream on the joints but dont know what it is anyone know or have suggestions what to use?
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    I've always used Dry Lube,
    Its in a stick about as round as 5cents, and 6" long.
    Can get it from supercheap/type places.
    Its like a waxxy white paste, put a little bit on each of the door sliders/stopper things and open/close the doors a few times, should work in and do its job. Put some on the door striker aswell, and if you can get some around the door hinges.
    Its normally just the little metal bit that stops the door opening too wide that dries out.
    Dec 2009
    Quote Originally Posted by romez View Post
    You need to buy Castrol PH grease is comes in a tub and it is white. You put this onto the check arms, top bottom and sides every few months. If there is a lot of dried up grease and dirt clean them first.
    Next you need some white spray grease, mine is CRC brand from Super Cheap. You need to spray this into the door hinges and the pivot on the A and B pillars for the check arms using the tube that comes with the can to stick in the nozzle. These pivots and hinges all have caps that come off to do this. If the caps are missing go to Holden and get new ones.
    I wrap the hinge in a rag and insert the tube from the spray can to avoid a mess as it will spray out.
    Lube has to go inside the hinges not on the outside, don't use WD40 as it is a dispersant and a solvent not a proper lubricant.
    1992 vp calais
    Mar 2010
    thanks for the help
  1. squeeky brakes
    By hotcommodore in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-07-2009, 11:15 PM
  2. Squeeky wheels.
    By voney in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2008, 04:05 PM
  3. squeeky tiller
    By dagar187 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-01-2007, 05:54 PM
  4. Squeeky brakes driving me insane.
    By MJR_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2006, 02:18 PM
  5. Squeeky brakes
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-06-2005, 08:29 PM
