Results 1 to 4 of 4
Thread: vp 5.0L has oil light issue
    VP 5.0 BERLINA's Avatar
    VP 5.0 BERLINA is offline 5.0 The only way to go
    VP BERLINA S2 5.0L
    Jun 2010
    wollongong
    Default vp 5.0L has oil light issue
    i have an issue with my 93 vp berlina V8 the oil light flickers on at idle im told it could be a stuffed oil pump if it is how hard are they to change?? i hope its the oil pump cause one of my mates suggested that the engine is wrecked i hope not
    VN Commodore
    May 2010
    Here is a diagram Would most certainly be on the bottom left . Would only be a matter of a couple of bolts and a wire.
    Worth a try.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id replace the oil pressure sensor first,it might just be faulty. Ive seen them cause the same problem as yours with the light flickering on and off..If the engine oil pressure is really low,you will be able to hear the engine rattle at idle,if the engine sounds ok and is quiet at idle,it will most likely be the sensor.The V6 oil pressure sensors are worth $25 from holden.I guess the V8 ones would be a similar price.You could also get a mechanic to connect an oil pressure gauge to the engine to check the oil pressures.
    VP BERLINA S2 5.0L
    Jun 2010
    wollongong
    the oil pressure is fine turns out it was the oil in the engine was to thin and wasnt pumping through properly but now ive found i have a rear main oil leak so i guess its engine out for me
  1. Odd hazard light issue
    By Semaj in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-07-2009, 11:33 PM
  2. VS dash light Issue
    By Void in forum V6 Development And Modification
    Last Post: 04-04-2008, 07:58 AM
  3. Break light issue
    By LUMINA ANIMUL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2007, 04:28 PM
  4. Brake light issue
    By guss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2006, 11:35 PM
  5. another light issue!
    By 5spdVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2005, 09:39 PM
