Results 1 to 5 of 5
Thread: VN V6 not charging
    Jun 2005
    Default VN V6 not charging
    My VN doesnt seem to be charging. Its broken down on me twice because it seemed to run on battery power with nothing coming from the alternator. I changed voltage regulators on the alternator and nothing changed. Any idea why? It only seemed to charge once yesterday. I ran the engine for a few minutes and it was charging at 14V, but after driving, it wasn't charging. Im guessing something is loose?
    Also, where is the earth strap on a V6?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Dec 2009
    Is the battery itself OK? Maybe charge it up with a battery charger and then get it load tested. Otherwise you may have some faulty diodes in your alternator or as you say a loose wire. Does the charge light come on at all?
    There are several earths on the engine block I can't remember off hand where the main one is that handles the starter motor's current.
    92 VP Series 2
    Jan 2009
    East Brisbane
    I'd be starting with some new battery terminals and I would clean up the earth that connects to the body of the car right next to the battery itself, thats just me though.......
    Jun 2005
    It looks like the connection on the back of the alternator is a bit corroded. It snapped as I was trying to undo it, so hopefully if i replace that connection it will fix the problem.
    Dec 2009
    Quote Originally Posted by stocky View Post
    Bad joints create heat so check that it has not melted the plastic in the alternator where it comes out the back of it.
    If the wire needs replacing you can cut it back and recrimp a new bit in with a new lug. You should use proper crimp lugs and a compression crimping tool to get a good and long lasting joint. Pliers or cheap crimpers are no good for this connection given the potential load. I'd then cover the crimp joint with some heat shrink that has a sealant/glue in it to keep moisture out.
    If the battery terminals are not heavily corroded they should be ok, don't get those ones that you bolt or clamp onto the cable. If they are a bit corroded some boiling water poured onto them will be enough to clean it off and when you reconnect them to the battery don't over tighten them and cover them in vasolene it will stop them corroding again.
LinkBacks (?)
  1. over charging?
    By chaster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2010, 05:50 PM
  2. Not Charging
    By ])R@G()N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2010, 01:41 AM
  3. turbo charging vr v6
    By pen15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2008, 01:56 AM
  4. charging
    By Mr Ute in forum Yella Terra
    Last Post: 27-04-2007, 03:29 PM
  5. VP 5.0L calais not charging
    By FCCOOL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2005, 03:31 AM
