Hey guys i've got a series 1 vn manual. just wondering what i would have to do to put a series 2 motor in it, as the series 1 has blown up... and whats the go with puttin the manual on the series 2 as it has a 8 bolt flywheel instead of a 6?? any help would be greatly appreciated!!
yeah well the series 2 is still in the car so i can get everything need, just more worried about the gearbox
cheers for the reply
I am pretty sure the early VN motors had a different crank shaft if they were auto or manual but the later motors the crank shaft is the same. You should be able to get a flywheel to suit the later motor? I think your also meant to use new bolts when you replace the flywheel as well.
I went from series two manual engine to a series one auto engine... All i needed was the crank adapter. From what i know, the VN's have 3 different engines...
Serious one - AUTO
Series one - MANUAL
Series two -BOTH
You will probably need an adapter to hook your crank up if your switching between any of these 3....
I build websites for cheap.
hey guys i hav a 91 vn executive i hav just pulled out the original seris 2 motor and auto and put in a series 1 motor and manual but it wont start now it kicks over but doesn't fire was just wondering wat u all thought? all help would b appreciated thanx Jason
