Results 1 to 4 of 4
Thread: need urgent help/advice!! with my vn
    vn executive 5spd
    Jun 2010
    Default need urgent help/advice!! with my vn
    hey all i hav a 91 vn series 2 auto and i also hav an 88 vn series 1 manual, the series 1 is defected and the series 2 has a blown motor, iv just pulled the series 2 motor and auto out and put the series 1 motor and manul in the series 2 all went well with the conversion except it wont start now atm im running the series 2 wiring loom and all seems to be ok its just it wont start pretty sure it has no spark? can u give me any advice on wat to do??? all comments appreciated
    Thanks heaps
    Jason
    Dec 2009
    It's cranking but no start? The 2 things you need are fuel and a spark so your going to have to check if there is a spark first of all. You can just pull off a few spark plug leads and crank the motor if there is a spark it will jump from the HT terminals on the coil packs down to the screw heads holding the packs in place. If no spark check your wiring. If ther eis a spark check that you have fuel start with the fuel pump and then you may have to check for an injector pulse.
    How much of the later wiring loom did you use and are you using the same ECU?
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    When cranking, accessories get shut off. Make sure you haven't connected fuel pump or ignition power to a source that shuts off when you crank. I know someone who did this to the fuel pump and it drove him nuts for 3 days, checking & rechecking. I think I narrowly avoided getting punched when I guessed this first go after he'd fixed it.
    Warranty Void
    vn executive 5spd
    Jun 2010
    i hav used the series 2 loom on the series 1 motor, i hav also used the series 2 coil pack on the series 1 motor will tht make a difference?
  1. Need advice urgent
    By Fun_Bucket in forum General
    Last Post: 08-07-2009, 06:53 AM
  2. need urgent help or advice
    By mitmit in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2009, 02:01 PM
  3. need urgent advice
    By shonky12 in forum The LAN Lounge
    Last Post: 25-07-2008, 10:46 AM
  4. Advice needed URGENT
    By GMBanisher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2008, 08:20 PM
  5. Urgent Advice Needed!!!
    By milesvs96 in forum General
    Last Post: 23-02-2008, 10:34 PM
