Results 1 to 15 of 15
Thread: Vn cluster plastic glass swap
    91 vn s
    Jun 2009
    Adelaide, SA
    Smile Vn cluster plastic glass swap
    The clear dial cover on my lvl 2 cluster has always been foggy and feral looking, not to mention it has a big crack running through it. Would a plastic clear cover from a VR/VS cover fit? or would it just be easier to go back to the wrecks and get one from a VN?
    thanks
    Also while it's out i might try to fix the sticky guages while i've also got my friends fie point solering iron.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    A L2 lens from a VR will fit if you swap the warning lamp cards over.
    and 3 Dangerous non ABS VN's
    91 vn s
    Jun 2009
    Adelaide, SA
    Thanks for your reply, ive only got the cover here, separated it from the cluster at the wreckers ages ago and has been living in a box.
    So I'm guessing that it won't be a straight foreward swap over i.e. the clips wont fit?
    i just dont want to take the cluster out to find that the lens doenst fit thats all. Thanks
    88GreenVN's Avatar
    Jun 2006
    Lens frame is identical from VN to S1 VS. S2 VS has the same shape and will fit too - just the lens is clip on not glued as in the VN to S1 VS.
    Take the 3 screws out of the bottom of the lens and remove the smokey cover. The warning lamp defussers will fall out. Replace these from your Vn lens and you wil have a new lens cover.
    91 vn s
    Jun 2009
    Adelaide, SA
    Sweet, I'll have a shot at this tomorrow then.
    While your online, where exactly is the 3 pin voltage regulator? I heard that its above the fuel/temp guages, i heard its above the tacho. all the guages are sticky and slow to respond, so a fix is hopefully in line.
    88GreenVN's Avatar
    Jun 2006
    http://forums.justcommodores.com.au/...-1-cracks.html
    ^^ This should help you find them
    88GreenVN's Avatar
    Jun 2006
    A set of VR/VS gauges will work heaps better (smoother) than the VN units if the voltage regulator is soldered up (no cracked solder joints)
    91 vn s
    Jun 2009
    Adelaide, SA
    Ok then, thanks a lot for your advice. Will have a crack at this tomorrow
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    I tried using a vs cluster in my vn series 2 and it didn't work. Is there a way to fix the plastic with like plastic light repair kit or would that not work.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by M3ZZA View Post
    What part did not work? If you change the warning lamp diffusers it should fit up no worries. I have heaps of lenses from VR and VS and use them to replace busted up VN units.
    I've got several lens screens - but it's almost impossible to get them out of the frame without busting the thing.
    May 2010
    VIC
    Warning lamp defuses whats that ?
    And i meant that can you recondition the plastics some how?
    88GreenVN's Avatar
    Jun 2006
    The warning lamp cards are along the bottom of the lens behind the dark strip.
    The lens will come up mint with a little polish - fine grade and a little elbow grease
    May 2010
    VIC
    Oh ok because when i tried the vs cluster it wouldnt even show the tacho working and when i indicated they wouldn't work but the hazards did and when the car was tuned off the right hand blinker logo was lit.
    88GreenVN's Avatar
    Jun 2006
    The cluster is not the same at all - but the lens will fit the VN cluster if you change the warning lamp cards. You can also fit the VS gauges to your VN cluster case. I've made plenty of Vn/VS gauge conversion this year.
    You just need to use the VN PCB (backing on the cluster) and the VN voltage regulator and it will work no problem
  15. #15
    88GreenVN's Avatar
    Jun 2006
  1. vr dash cluster swap over
    By 88pete in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2010, 08:31 AM
  2. VN Intrument Cluster Swap
    By xXBoofXx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2010, 10:31 AM
  3. [SA] WTB: VL dash cluster (tacho type) AND VL drivers side plastic windscreen mould.
    By <atomicL93> in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2009, 08:25 PM
  4. [VIC] WTB/swap vn bt1 dash cluster
    By NOT.BT1 in forum Swap / Wanted to Buy / Trade
    Last Post: 03-11-2009, 09:46 AM
  5. Wh cluster swap
    By joebloggs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2008, 01:24 AM
