as title suggests, is there any easy way to get the loom
out of the firewall where it goes thru to the ecu??
there is three big rubber lugs on the inside of the grommet, do i just get a screwdriver
up there and poke round till she pops out?
thanks in advance
chris
Just get your hand up there and squeeze the prongs and push out at the same time. Work your way around doing one at a time and it will come out. Might take a few goes to get it, but it should pop out eventually.
Thomas is right. It's just two prongs on the inside of the car. Squeeze them and it should go through the firewall.
yeah but the rubber is hard as hell. will let ya know how it goes
I just get a big lever on the outside of the firewall and lever it out.
A little CRC can help it back in if you have to fit it back at some point.
and 3 Dangerous non ABS VN's
