hi guys... this is my new 1991 VN excitive (V6).. its all standed an has its problems.. all problems are posted in there proper posts an problems are being sorted out.. (im looking to do this old girl up) im going to put a set of 17 size rims with a low profile tyre on her with a nice exhaust system..then im going to drop her, so her top wheel archers just sits above the top of the tyres... tho i want her to have more bottom end an mid range power then she has now!! but im not shour in what i can do to get that from her... so has anyone got any tips on haw i can do this???
im low on budget.. i wont this car to look mean an sound nice, but go hard
so any info will be nice!!
you'l never kno, you might just see her at the creek on a street meeting!!!!!
A Greenfoam tune will most definately help. VS super6 cold air intake, make sure your air filter is clean. Exhaust system too. and extractors.
I got the tune and the CAI and am too poor to afford a fancy air filter and exhuast system, but even with those 2 things i can feel a bit more grunt lower down in the rev range. good luck with the project
I would suggest to start with the basics first if not already done so:
Replace engine oil filter and engine oil.
Replace transmission filter, gasket and fluid.
Run injector cleaner through gas tank or professionally clean.
Replace spark plugs, leads, dizzy cap, rotor and coil.
Radiator Flush and fluid replacement.
Clean throttle body and ensure it is opening 100%
Check throttle lines for slack or stretching.
Clean or replace air filter.
Check and replace brake pads if necessary.
Check exhaust for leaks.
Check all hoses and belts for splits and leaks.
Hopefully some of that info is half usefull to you.
I am sure i have forgotten a few and the list is in no particular order! Most of the above you should be able to do yourself from a lot of the DIY's on this site. Made a huge difference in my VR after i did the above checklist! Good Luck!
yer cool thanks! the cars at my mechs now an wont be ready untill tusday (it is geting all that done) i havent got money problems or stuff like that.. i just spent $3000 on doing up our subaru an now i only get paid $1000 fortnightly an plus i stopped working on the subaru now as it was to big an hard of a converion job to swop it from a 2.2cc to a 20cc turbo engine.. so now its onto the VN
what type of headers should i get an what exhaust system? (rember this is our family car aswell) so it must stay in the illegal rang of the laws eyes
ps: what sort of body kit can i get that will fit my 1991 VN..
haw much am i looking at for a good set of headers an exhaust system an full body kit? an will i need to change the cpu unit?
