Results 1 to 7 of 7
Thread: Stage 2 shift kits.
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Default Stage 2 shift kits.
    Hey guys is it hard to install a stage 2 b&m shiftkit into a vn series 2 v6. And is it a worth wild mod considering the price ?
    cheers.
    VP Exec
    Jun 2005
    To see exactly what is involved go to the B and M website and download the instruction manual for the kits, available in pdf. You want 70239. Basically, it's remove the valve body and drill/fill a couple of holes in it and the plate, fit a stiffer pressure regulator spring and fit a couple of spacers/stops that reduce the volume of - hence reducing the time taken to fill - a couple of the accumulators. You will need a torque wrench - 1/4" drive - or a well calibrated elbow to refit the valve body.
    The only difference between the two B and M kits for the TH700/4L60 is the inclusion of a filter in the more expensive kit. The kit instructions have been reformatted to obscure this. (There are real differences between the B and M kits for some other trans. models.) It is cheaper to buy the filter from a local source.
    Missing from the kits are the sealing 'O' rings for the 2-3 accumulator as you are expected to reuse the old 'O' rings with removal and replacement. Sourcing new ones would be sensible with 20 year old parts I think.
    May 2010
    VIC
    VY Ex-cop
    Mar 2006
    i'd do it, ive done it, i'll do it again. hate them sloppy shifts. takes a few hours.
    May 2010
    VIC
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by M3ZZA View Post
    so its worth the $$$
    in my opinion definately. but if ya tranny is stuffed, a shift kit will screw it more.
    May 2010
    VIC
    cool thx 4 that.
  1. if you have a stage 2 shift kit
    By bigneilsen in forum General
    Last Post: 02-05-2012, 08:47 PM
  2. Stage 2 or Stage 3 shift kit?.....can someone just quickly explain
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 03:25 AM
  3. stage 2 shift???
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2008, 06:54 PM
  4. Shift Kits - Stage 2 vs 3
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2007, 01:36 PM
  5. stage 2 shift kits
    By hoon1 in forum V6 Development And Modification
    Last Post: 27-08-2005, 12:56 AM
