Results 1 to 13 of 13
Thread: vp dying a lil more each day :/
    vt wagon, vp s2
    Jun 2010
    Default vp dying a lil more each day :/
    hey,
    i recently sold my VT wagon and have down graded to my old VP sedan.
    in the last two years we have replaced fuel filter, radiator, battery, fuses, water pump, alternator, coils, plugs,oil filters an oil etc
    over the last month it has gotten lazy, struggles with start an stop driving, hates driving under load, so changed plugs an all came good..
    then today it felt asthough it was going to cut out but instead let off a massive backfire doing 110kms on highway. it basically kicked into limp home mode for the next 20kms but didnt miss a beat just felt asthough was driving a 4cyl.. got it home only to hear a strange kind of hissing/grinding noise when i got out to open gate.. left it running in garage an popped bonnet only to discover what appears to be tranny fluid all over the passanger side of the engine and seemed to be leaking from rad cooler pipes and there was a watery brown drip from near sump.. have tightened up cooler pipes an put new clamps on hoses...
    HOWEVER.. back in december i hit a roo on our road at about 100km an the bloody thing left a mass dint in the front bonnet smack in centre, smashed grill infront of radiator an the lights and there was gas leaving the radiator with a fair amount of pressure( assumed a/c gas??) radiator appears okay though so im stumped..
    i have noticed theres brown crud in the radiator which was there in old radiator too so i guess its made its way into new radiator via the water pump or hoses??? an my water pump now appears to be struggling.. does a few normal cycles then theres a thud an a vibration through the pullies an so forth..
    any idea's???
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    head gasket developing a leak?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    90 vn wagz and 90 vn sedan
    Feb 2010
    vt wagon, vp s2
    Jun 2010
    well it is looking like a option to burn it down the back paddock an buy another vt , however guy across road through it up on ramps an checked it all over.. seems my leak is gone for now since changed clips on hoses, the idle is smooth, now i just need to narrow down the knocking/ thud in the pulley's.. theres brown crap in radiator water which i assume is my fault since i used the original bolts again when i changed the water pump 2 yrs ago so will replace pump again an renew bolts, radiator has a small hole near top left corner from roo claws when it smashed through bonnet, so could i be looking at trans fluid leak in radiator aswell.. but with all these issues ive had no overheating what so ever :S i kinda hope i can save this car, with a lil work
    VN WAGON
    Sep 2007
    heres the story, as we get older each day we start to slowly die so do cars full stop/
    vt wagon, vp s2
    Jun 2010
    oh beleive me i am with u on that theory mean vn, but problem solved after all the fiddling with things like coils, dfi, fuel system etc.. ended up being the fan belt was slightly cracked and well in the 2 years ive owned the car ive never changed it but who knows how long it'd been on there before i bought it. as for the radiator it is looking good after a flush an some new coolant drove it 100km this morning and didnt miss a beat, im one happy girl now thanx anyways
    VN WAGON
    Sep 2007
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by havavb View Post
    Simple solution ditch the VP for a VN Cant go wrong there.
    yeah, the previous owner selling it would have replaced everything by now with new stuff recently. they thought stuff this, what a piece of crap, i have to kepe replacing stuff and by the the time they got to the last thing to replace, its a new car and nothing will go wrong with it for another few years.
    i can remember when VN's came out i was a first year apprentice, they had a recall list longer than the HQ holden. i was for ever fixing things on recalls, i can tell ya i got good at it.
    the VN was holdens biggest mistake, they should have never put on that work experience lad who designed it without a university degree.
    vt wagon, vp s2
    Jun 2010
    yeah ex had a vn calais 89, was dodgy as forever swapping fuses, fixing leaks and had a mind of its own electrically but mechanically we had no major issues at all over 3yrs. i dont think he even serviced it once an still got 1500 trade in back in 08.
    vn commodore
    May 2010
    ive owened 3vns and ive never had a problem with them apart from blowing trannies and defects due to putting stupid shit on them
    vt wagon, vp s2
    Jun 2010
    okays so im back to no car.. it started playing up again.. took into to auto electrician who told me s2 vp's arent compatible with scan tools??? is this right???? anyways he thinks his apprentice stuffed up the instillation on the CAS god knows how, but anyways its back in the workshop for a 2nd attempt at the CAS fingers crossed.
    vn_v6's Avatar
    Aug 2009
    victoria
    they are compatible, their practicly the same as a s1, almost a vr........
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by jessie-lea View Post
    A Tech 1 scantool can read the VN/VP ECU's and VP BCM modules.The mechanic probably doesnt have the proper type of scantool.Most newer scantools can only read OBD11 or CAN diagnostic systems, whereas the VP is OBD1 only.
    Holden are usually the only ones that have the Tech 1 scantool.You might have to see them,or you can flash up any error codes yourself by bridging the diagnostic connector with a piece of wire which flashes up codes on the engine light on the dash.Heres a link to a thread that shows a couple of pics and explains how to do this test.---Checking your Computer for Faults (VN - VP)---
  1. vz sv6 dying!
    By allanssv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-06-2010, 09:19 AM
  2. Why is my car dying?
    By Da_Blak_Ravn in forum Electrical Wiring / Questions
    Last Post: 08-10-2008, 10:32 PM
  3. Help! My VN is dying
    By down_with_the_system in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 01:24 PM
  4. My Car Is Dying
    By outlaw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2007, 10:03 PM
  5. my VS is dying help
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2005, 08:11 PM
