Anyone installed a Megashifter or similar in a VN-VP commodore?
I need to know what length shifter cable to get......
And if any mods/brackets were required to make it hook up to the T700?
Thanks
On most installations, the 5 foot cable supplied with the shifter is long enough. I've done quiet a few B&M installations, havn't done a Commodore though. No mods to fit a B&M to a T700, the brackets are supplied.
Thanks.
Only problem with the B&M I got is it is second hand and is just the shifter and surround. No brackets or cables (except the shift position cable) came with it.
These are what you need:
Transmission bracket: B&M 35498 - B&M Transmission Brackets and Levers - Overview - SummitRacing.com
Shifter cable: B&M 80605 - B&M Performance Shifter Cables - Overview - SummitRacing.com
Thanks
I did find the bracket, but I got a different part number. This site reckons one is for the Bandit shifters.
http://www.chrismillsperformance.com...=305&Itemid=30
Thanks again tho
Just need to chase up the alloy T-Bar handle now.![]()
