I own the Calais and not long back i pulled the 5 speed and motor out of a VP exec and am considering the swap over. I've heard that it can be a pain in the arse with sensors and what not but are there anyone on here that has done this in the IRS calais and did they run cable or hydraulic clutch? The motor the box is on was using water and leaking coolant but not too many kays on it so was thinking about new gaskets and a clean up woul be enough. Whats your opinions on the matter?
Cable clutch - very straight forward conversion. Should take you slightly over a day.
Reaper
How bout the tail shaft, they should be same length right?
The sensor problem is only VR onwards. VN/P dont have this problem, and despite what some uninformed people will tell you, you can run a manual gearbox and retain the auto computer.
Both of mine are using cable clutch. Not really worth converting to hydraulic unless your planning high hp/torque.
Do you still have the car that the gearbox came out of? Better to have all the parts on hand, because its hard to find certain parts at wreckers, because they wont usually part them out separately.
Oldies were on to me about getting rid of car and forgot some important ingredients at the time like pedal box. But i do have one from a VC.....?
