Results 1 to 7 of 7
Thread: VN...oxygen sensor problem...please help
    VN EXEC
    Feb 2010
    Default VN...oxygen sensor problem...please help
    Hi guys, did my error code check and turns out ive got the following issues-
    Code 13 - Oxygen Sensor (O2)
    Code 44 - Oxygen Sensor Lean (O2)
    Code 45 - Oxygen Sensor Rich (O2)
    My car runs on LPG and Petrol, im just about to go on a big road trip journey, how do i get this fixed,
    please please help me!
    thanks
    VR EXECUTIVE
    Apr 2010
    Tasmania
    Replace the sensor with genuin holden one and it should be fine, cheers Bob.
    VP Exec
    Jun 2005
    It might or might not be a faulty O2 sensor - they do have a service life - so it won't be a bad thing to replace it if it's more than ~ 80 000km old but the codes may simply be because of the LPG. There is another recent thread with a similar question.
    If the LPG isn't correctly tuned those codes can set.
    Even if the LPG is correctly tuned, the rate at which the mixtures are corrected on LPG will be so slow as to be interpreted by the ECM as a fault. delcowizard has pointed out in the other recent thread that using a two map memcal allows the O2 sensor code conditions to be ignored while running LPG. Otherwise, you just live with it.
    VN manual, VC 5L Auto, VT Senator 5.7, VL 308 4spd
    Aug 2008
    SouthWest WA
    What cheap6 said. My VN runs on straight gas and those O2 codes will always come up, no matter what i try, so you just live with it.
    Being duel fuel will do the same thing.
    Replace them anyway just to be sure, and then have fun on your trip.
    Follow Your Dreams......RIP Brocky 1945 - 2006......May God Rest Your Soul
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The codes can also pop up if the connector to the O2 sensor is buggered. I had this issue with my wagon a few years back when replacing the sensor. It still failed and spat out codes all the time. Finally replaced the connector for it to not have a code again from the o2.
    and 3 Dangerous non ABS VN's
    VN EXEC
    Feb 2010
    sorry im not very clued up...
    so where do i buy a new o2 sensor and how do i fit it, also is it worth me doing the connecter at the same time? easy job?
    thanks guys..
    VP Exec
    Jun 2005
    Probably best to jump to your other post so everything is in one thread.
  1. No Oxygen Sensor.....
    By ScoHar in forum V8 Development and Modification
    Last Post: 20-07-2009, 07:38 AM
  2. oxygen sensor vs
    By Zipster in forum Electrical Wiring / Questions
    Last Post: 29-12-2008, 02:06 PM
  3. Oxygen sensor
    By wogski in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2006, 10:23 PM
  4. which oxygen sensor do i need
    By rob_phill in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2006, 09:31 AM
  5. oxygen sensor
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 04:33 PM
