Bolts on to the TB on some VP's, part of the fule line going to the right hand side fo the fuel rail. What is it and what does it do?![]()
That would be your fuel pressure regulator.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
Except that it doesn't appear to have provision for a vacuum hose connection and it's the wrong shape. I think that it is a fuel line pulsation dampener - fitted as a factory rework to VN and perhaps early VP to reduce an NVH problem but it's been a while since I've looked at one.
Worth putting it into my VN?
I think the later models had the pulsator/dampener fitted on the pump assembly inside the fuel tank.
yep, its a fuel line damper to eliminate fuel line hammer. and no it doesnt go in the tank, it sits on the fuel input to the fuel rail in the engine bay, i think it sits on the inlet manifold near the throttle body or on the throttle body, cant remember from memory.
As I said, its only the LATER MODELS that have it in the tank.Not the one pictured.Otherwise I would have said THAT one goes in the tank.
yeah it bolts to the Throttle cable bracket that bolts to the TB.
This is a ute pump assembly,but the pulsator/dampener is on sedans and utes and wagons.It is marked in the pic below.
[IMG][/IMG]
oh is that what that bloody thing is, i always thought it was just a push over connector, i never put any more thought to it whatsoever. cool.
So what shout the car be like with one as opposed to without?
Unless you are paying particular attention I doubt that you will notice any difference, especially with the extra rattles and noise associated with 20 years of wear and tear. You might notice occasionally some additional noise from the firewall area as the fuel lines vibrate against the body.
