Results 1 to 9 of 9
Thread: rear suspension bushes stuffed
    92 VP Series 2
    Jan 2009
    East Brisbane
    Default rear suspension bushes stuffed
    hey guys, have been getting a bad clunking sound the past few months from the rear of the car and its just getting worse and worse. i already knew that my rear UPPER control arm bushes were stuffed but have now found that also the rear LOWER control arm bushes are completely f**ked too (theres hardly any of the bushes left, they've all fallen apart) and also the rear sway bar bushes on the ends of the sway bar are stuffed too. i dont have much money so i dont really wanna spend money if i dont have to. my question is am i able to just leave all these problems and handle the clunking sound, or if i leave them too long will parts start really breaking if i dont get it fixed asap. if this is the case what order would you's replace the bushes in? just cos i doubt im gonna be able to save enough money to do it all at once, first year apprentice wages are really that bad thanks for any answers
    vs commodore
    Oct 2009
    Tamworth NSW
    I was in the same spot.I couldnt pay for them all at once.I fitted a couple at a time and found that the new bushed flogged straight out because of the movement from the other worn bushes .I then replaced them all at once with nolothane type bushes and its now a different car to drive,heaps tighter,just like it should be.
    BURNOUT BAZZA's Avatar
    BURNOUT BAZZA is offline BOB DA FITTER
    92 VP calais, 81 VC Commodore
    Apr 2009
    Skye, Vic
    if i was u. id go down to ya local pedders and get them done on the eazy pay plan things. cause u need to do them all at once. and if u dont do it soon. metal rubbing on metal it not good for the bolts holding the arms on.
    u leave it to long and they will wear out and break.. next thing ur diff with fall out. thats an extreme case scenario i know but can happen. i would hate to be driving ur car. must feel very loose and have a lot of axel tramp on take off.
    VY Ex-cop
    Mar 2006
    then next time you go around a round about and hit a bump you could skid off into a stobie pole with stuffed bushes. another extreme case scenario.
    Apr 2009
    Skye, Vic
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    seriously. take the car off the road untill you get it all fixed up.......before you kill yourself or someone else mate.
    VN Calais With All The Factory Fruit I Need!
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    Shit my VN is doing the exct same thing. Is it expensive to fix? can you do it yourself?
    92 VP Series 2
    Jan 2009
    East Brisbane
    thanks heaps everyone for all the replies. i know to make this a priority now. and yer as sik_dose said, is it hard to do yourself with only basic hand tools? or is it another one of those things that i should take it to a suspension shop to get done?
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    you can buy upper and lower arms with new bushes off ebay. the only bushes that need to be fitted by a mechanic are the lower ones that are in the diff housing
  1. Suspension Bushes.
    By ROZ in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-05-2010, 07:14 PM
  2. Suspension Bushes stuffed?
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2008, 02:10 PM
  3. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  4. Rear Suspension Bushes
    By DaPlaya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2007, 12:40 PM
  5. suspension bushes
    By blaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2006, 09:46 AM
