Results 1 to 4 of 4
Thread: vn fuel pump winding but car not starting....
    vn berlina wagon
    Jun 2010
    Default vn fuel pump winding but car not starting....
    hello just needed some extra brains for my hubby who is stumped 3 days ago the car was running fine he decided to fix a slight leak around the tank and pump since then the cars fuel pump windes but the car wont start i'm stumped checked all fuses and relays just dont have a clue what to do with it fuel pump seems in good condition too
    plzzzzzz helllppp!!!!
    thanks courtee
    VP 5.0 BERLINA's Avatar
    VP 5.0 BERLINA is offline 5.0 The only way to go
    VP BERLINA S2 5.0L
    Jun 2010
    wollongong
    BURNOUT BAZZA's Avatar
    BURNOUT BAZZA is offline BOB DA FITTER
    92 VP calais, 81 VC Commodore
    Apr 2009
    Skye, Vic
    it could have an airlock in the line thats stopping the fuel getting the the engine. loosen one of the fuel holes and see if its pumping.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Ive found that you need quite a bit of fuel in the tank to get the pump to prime if the pump was completely dry like it would be if you drained the tank below the sender unit entry hole height ...I put in 10 litres after changing to a brand new pump and the car wouldnt start.. you could hear the pump running ...remembered all the stories about the fuel cooling the pump and the fact you could burn it out if I just kept winding it over so I stopped and went to the servo and got some more fuel......chucked in another 15 litres and it started straight away and ran fine..I figured the swirl pot didnt get fuel when I put the initial 10 litres in and the little bit more over flowed the edge of the swirl pot and filled it up, primed the pump and off she went...havent had any dramas since and have run the tank to the low fuel alarm and it still picked the fuel up ok.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Fuel Tank,Fuel Pump Assembly and Swirl Pot.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2011, 10:12 PM
  2. fuel pump replaced, car still not starting
    By crewsy in forum V8 Development and Modification
    Last Post: 21-08-2009, 05:00 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. VK 304 not starting (fuel pump?)
    By Pav in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2008, 11:43 AM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
