hey people im coming to the closing stages of my vn v6 turbo build, i have disconnected the pcv valve
that goes from the back of the manifold/block and goes to the throttle body BUT i have been told there
is also another one that lives in side the manifold under the big bolt on top front of manifold, see the
pics below i have attached one of the manifold and one of the apparent pcv valve that lives there
NOW should this one also be crimped shut etc ? cheers for your help . . . . mark
{H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
I think you will find that is coolant.....but take it out and have a look.
You shouldn't need to disconnect the PCV valve as it is a one way valve. It won't let pressure back into the crankcase unless it is stuffed and always open.
its the only pcv valve the other pipe off the TB into the manifold or tappet cover on the passenger side is the inlet of fresh air it has no pcv valve in it
