Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By delcowizzid
Thread: vt coil pack on vn series 1????
    VN Calais/VT commodore
    May 2008
    Default vt coil pack on vn series 1????
    hey i was wondering if anyone has changed their series 1 coil pack and dfi.....with the later model mounting bracket.... i have just tried to do this but the series 1 mounting bracket also holds the alternator..... any ideas???
    VC
    Oct 2008
    Yes it can be done, not hard but a bit of effort is required. I did it to the V6 I put in my VC. I took the later model mounting bracket and cut it down with a hacksaw until it was a flat plate, trued it up with a file and then screwed it to the original VN mounting plate. At least it is aluminium and quite easy to cut.
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    Can't you pull the bracket off when you take the coil pack out of the VT? I assumed it would bolt straight up, could be wrong.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    May 2008
    im not sure, the alternator uses the same bracket that the coil pack and dfi use on the vn engine and on the Ecotec the alternator is located on the other side..... hmmmm do i cut down the original bracket
    VC
    Oct 2008
    No, you cut down the VT bracket so it can bolt onto the original VN bracket, should take no more than an hour to do and then everything remains in the same place as original.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    man just unbolt it and bolt it on the vn bracket fits perfect no cutting involved
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Should do, have a VY sv6 coil on my vn, just modified the mount a bit, used some spacers and a longer bolt.. no issues at all
  1. vs series 2 coil pack?? any coil pack will do????
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:52 PM
  2. fs: Series 1 coil pack
    By MUNTED6 in forum Parts And Other Items For Sale
    Last Post: 03-09-2007, 10:00 AM
  3. Coil Pack Series 1 & 2
    By GE4CE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 06:18 PM
  4. VN Series 2 Coil Pack
    By PMark in forum Electrical Wiring / Questions
    Last Post: 01-08-2006, 09:12 AM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
