iv swapped the engine over in my vn s pack and am thinking about rebuilding the old one, just after some info about how hard it is and the costs involved, i was thinking about replacing all bearings and the piston rings.
cheers
not that hard. few hundred i reckon for just bearings and gaskets. dont use aftermarket crap gaskets, use genuine ones, they might cost more but they will last longer.
cheers, theres no need to do anything to the rockers when i do all the other stuuf is there? i changed engines because there was a rattling noise at the back of the engine which i was told it was the crank bearing
there is no need but i believe there has just been a set of high ratio rockers released for the vn series 1, would be a good mod while your at it. Or just throw in a bigger cam for fun!
from my experience, yes they are. ive never done engines with aftermarket crap cork gaskets and the like and paper gaskets without the beading, all engines i have seen with aftermarket gaskets eventually leak prematurely or immediately, genuine gaskets are far better made and designed and prevent leaks if put on properly.
what about copper head gaskets?? lol
thanks, i never found out if it was the crank bearing properly, there was a loud knocking noise and i wanted it changed before it did get worse, so i chucked in a secondhand one so i can fix it, i'll just have to find out when i pull the engine down.
you wouldnt no the price on them high ratio rockets would you
1.9:1 rockers are about $550ish. Contact MACE engineering.
I say give it a go, I did a automotive course in year 10 when i was in highschool and i can say it was the best thing i have ever done, it has saved me thousands.
Just take your time, be methodical and if it helps take step by step pics as reference items later. When you break it down there isnt much to an engine they are pretty straight forward. Make sure everything is clean as you go and then seek advice when you arent sure.
Matt
yeah thanks i wont be touchin it for a couple weeks yet need to clean the shed out a bit before i start. how hard is it to line up the time when putting it back together
unless u go spastic on the cam and heads and what not just dot to dot (timing marks) would be fine
WTB: VY/VZ front buckets any spec
WTB: VR/VS right hand side doors preferably white with electric motors for windows and locks
na i wont be doin to much to the cam and heads just replacing all bearings and gaskets to tidy it up, and wat ever else i decide along the way
another thing to make it easier when you undo it all is to use some white out or something and put marks across two pieces then you just need to line the marks up, but as mentioned above just line the dots up.
When you pull big end bearings and stuff off with the crankshaft number each bearing cap as they need to go back on in the same spot. Little stuff like that makes a difference, if you take your time and be thorough you will be fine. Then be slow and methodical when you put it back together, get a workshop manual and a good torque wrench for when you reassemble so you get all the various torque settings right, and use engine oil to lubricate stuff as you put it all back together i.e pistons, bearings etc etc. And speaking from someone who bought an engine where it wasnt done stagger the gaps in the piston rings so that they dont all line up.
Matt
