hi
just finished doing auto to manaul conversion
have a bad vibration coming from clutch flywheel area.. do you have get the flywheel balance been told you cant????
did you fit a vn flywheel or was it a vs onethat will do it
another thing is did u put the brass bush in for the input shaft in the crank... or dont they have those on the holden?? but it could also be the tail shaft out of alignment
does it in N too
yeah put the brass bush in the crank
just find out that the gearbox and flywheel are out of a vs... vs v6 have a different flywheel??
yeah ecotec ones botl up bont are balanced differently.
that will be your problem mate.
get the vs fly balanced to your old vn auto flex plate.
heres a funny story i put my engine and box in and had a mate help me went in all good and ran well but when u floored it it vibrated the doors of it it turned out to be the little banana cross member was put on backwards and the balance weight that comes off the gearbox was hitting on it under acceleration i thought the same took the banana thing off and turned it round all good
