can I use a vp timing cover and crank angle sensor on a series one vn v6? i have put a series 2 intake manifold on a s1 engine and need to do something with the bypass hose outlet as its too small.I was going to take the old cover off to check out the noise with the timing chain and thought I might swap it over at the same time but I wasnt sure if the front pulley will work with the non adjustable later model cas?
