Results 1 to 19 of 19
Thread: Cluster Warning Lamps
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Cluster Warning Lamps
    Here are all 4 of the Warning lamp cards for Level 1 and L2 clusters VN VP VR & VS
    The VN units in a VP make all sorts of horrible combinations - nothing works
    The VR VS units are mainly the Sat Belt warning replaces the Press Remote.
    Attached Thumbnails Attached Thumbnails Cluster Warning Lamps-l2_lens_diffussers_small.jpg
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Here is a better photo.
    Attached Thumbnails Attached Thumbnails Cluster Warning Lamps-l2_len_diffussers_ab.jpg
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Got a pic showing all clusters and all models (obviously your only missing lvl 3 atm.). Good post though.
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Hmmmm I have always wondered why the VN dashs had two of the "PWR" symbol....
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by dans_vz View Post
    I think the extra PWR was for the export cars - Not sure what it did tho.
    Tuned VX SS
    Jun 2010
    ah, now I see, you know I just went to the trouble to put the vr gauges inside the working vp cluster just to get those lights right, now i will have to change them back to get that last annoying light to come up.
    thanks
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Huntington View Post
    thanks
    VP Diffussers have been sent
    88GreenVN's Avatar
    Jun 2006
    Here are the Level 3 diffussers. (the first is from a Toyota cluster) I'll check a VN Holden unit to see if it's any different.
    Attached Thumbnails Attached Thumbnails Cluster Warning Lamps-l3_diffussers_a.jpg
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    hey 88GreenVN,
    sorry to steal your thread.
    i put a vn cluster in my vp and left indicator doesnt light up on the dash. do you know which wires need to be swapped around to get it working and on which plug? cheers
    George
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by georgeonboost View Post
    hey 88GreenVN,
    George
    Move the light blue wire on connector 1 over to slot 10. To make sure, look at the list on the back of the cluster it will have what pin out number it is - 10 or 11. I think it's 10 tho.
    VP Exec
    Mar 2009
    Melbourne, bayswater
    Hey, dont want to intrude on your thread but i have a quick question.
    Today i got a light come up on the cluster, it looks something like this (!) with a circle around it. what does that mean?
    Thanks, Terry.
    vx gen111 wagon
    Jul 2009
    perth
    check light do a code test to see what is playing up see how to,s for codes
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    its a break fail light, if you've updated to a calais dash like me it could possibly be a check engine light ( mine shows up as break fail )
    Officially In The SunRoof Crew
    '05 VZ Berlina September '09 - April '11
    VP Exec
    Mar 2009
    Very interesting, when i brake it goes away, when i let go of the brake it comes back on.
    If i change the pads will it go away? Or is there something serious going on?
  15. #15
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by VnPlayer View Post
    I'd check all the eaths on the tail lights first - give all the wires at the back of the globes a good wriggle when on and off the brakes - see if any flicker. Also I'm guessing you have checked all the globes by now and are working correctly as far as you can tell. The wriggle test may show up a bad earth.
  16. #16
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    sorry for this thread dig, but i have a light coming up on my vs, it goes away when i break, it is the light in between abs and check engine, ( post number two, bottom left hand side, second from the left) that light is coming up. Is that just a globe problem?
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Skid Bro View Post
    I think that is the brake fail warning lamp - check al the tail/stop lights before you pull the cluster out
  18. #18
    calais24/7's Avatar
    Jul 2009
    I had my number plate lights disconnected. Their plugged back in now, hopefully that has fixed the problem. I still have no reverse lights but im getting there
  19. #19
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by VNVacationer View Post
    thanks for posting, most illuminating
    Wonder why you posted this - adds nothing to the thread - not even remotely funny. But your post count hits 20 - good stuff.
  1. dashboard warning lamps too dim
    By jeepster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2010, 03:12 PM
  2. dash warning lamps
    By python_hunter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2009, 12:13 AM
  3. difference in warning light between vr-vs cluster
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-05-2009, 12:45 AM
  4. VT Calais cluster lamps blowing
    By VSB in forum Electrical Wiring / Questions
    Last Post: 01-08-2008, 01:40 AM
  5. various warning lamps on
    By nu2com in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-04-2006, 06:34 PM
