Results 1 to 5 of 5
Thread: Earth wire...please help!
    VN commodore
    Jul 2010
    Default Earth wire...please help!
    I have been having problems VN. It all started to go wrong when the car just stopped while doing 100km's. Since then...we have replaced the crank angle sensor and water pump. It is still stalling or wont start, we think we have found the problem with this wire. does anyone know where or to what this earth wire goes to? (please see pic) would appreciate any and all help.
    Attached Thumbnails Attached Thumbnails Earth wire...please help!-earth-wire.jpg
    Dec 2009
    I believe it is an earth for the ECU to the engine block. That looks like a replacement lug so make sure it has been crimped on properly and not just with a pair of pliers or those cheap crimping tools. I had to fix the one on my VN and from memory the stud came out of the block and it goes into the water jacket. You can check the resistance to the negative terminal of the battery and if it is high remove the stud and clean it up.
    VP Executive
    Mar 2010
    if u have a good wrecker with a yard full of commodores i have found lately i am learning a heap from them, ie i am finding where the wires go and what goes where.
    VN commodore
    Jul 2010
    Thanks for your reply... Does the earth for the ECU need to go to the engine block or if its just to anywhere on the car body? I dont know much about engines (my brother in law is helping)...but I can do basic wiring lol
    If this wire is faulty...would it cause the engine to keep stopping..or not start at all?
    VK V6
    Mar 2010
    NZ
    It must go to the engine block, and yes it will cause those problems. If you were to disconnect it the ECM wouldn't have a main earth at all, and it needs to be a good connection to get clean signals from all the sensors.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. only 1 earth wire for stereo install ?
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-11-2009, 07:10 PM
  3. earth wire?
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2009, 03:22 PM
  4. Why is the earth so hot?
    By ECILOPX in forum Electrical Wiring / Questions
    Last Post: 05-04-2006, 12:56 AM
  5. vs earth
    By jds303 in forum Car Audio
    Last Post: 31-03-2006, 07:30 PM
