Hi Guys,
Just wondering if you can get a vacume cleaner into the fan, is it hard to get too, I think I have leaves in the fan and also, the two airvents on the dash in the middle, are they able to come out to clean inside there, I'd love to airblow the whole system lol.
Cheers,
Sean
If you remove the trim under the dash on the LHS of the car you can access the fan. Removing the glovebox helps.
Put the vent system on reciculate to allow access.
If the leaves have got between the fan and its housing, operate the fan to blow them through or drag them back to the side that you can access.
Regularly cleaning the rubbish from the ends of the plenum at the base of the windscreen with the bonnet open will help stop more leaves getting in.
If you are really keen, you can remove the wiper arms and plenum cover and vacuum out the leaves and wipe the dirt out with a damp rag.
