Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Just locked keys in my car
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Default Just locked keys in my car
    Tried a coathanger etc, cant get a spare key as its a solex locl, any ideas?
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    May 2010
    Croydon, Vic
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I bend the door open and get a coat hanger inside the car and lift up the door lock, takes forever but it worked. Cant do it anymore tho since I removed mine
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    May 2010
    Croydon, Vic
    vn exc
    Apr 2009
    I did the same I locked mine in over night in the
    Ignition and when I finally realized were they were
    I was shocked my car was still there anyways
    Bust the boot lock and stick a flat screw driver
    In there and turn it it should open then kick the
    Middle of the seat in then get a long stick ( I used a pool cue)
    And then unlock the back door
    Worked for me
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    ^^^^^^^That sounds like the worst idea ever
    Commos arnt real easy to break into as far as using a coat hanger/packing stips goes. The back doors might be easier to work with as they have a bigger likage setup to get at.....but thats a maybe.
    As far as being wreckless and smashing screw drivers into locks, well they dont do so well. But if you do that, your better off smashing a window. Cheaper to fix and you wont have a odd ball key for a new lock you will have to get.
    Reaper
    dirt drifter's Avatar
    dirt drifter is online now white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    maybe find a door off the same model car, take off the door trim and have a good look at the handle/lock setup. hopefully u can find somewhere to poke around with a coathanger etc to unlock it.
    if not, the rear 1/4 window is probably going to be the easiest to replace if u have to smash one there is a how to replace 1/4 window thread around here somwhere if it comes to that, hopefully it wont
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by dirt drifter View Post
    This is a common myth, one of the normal windows would be cheaper to replace (and easier). Id just smash the rear door window if it came to that.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    92 VP Series 2
    Jan 2009
    East Brisbane
    Another vote for racv, just give them a call and they should be able to quote you how much it would be for them to come out and do it
    Dec 2009
    Honestly smashing windows, busting locks and kicking things in are about the dumbest ideas I have heard, why break the car? I locked the keys in my VN, not meant to be able to happen but the mechanism in the drivers door that stops you doing it wears out. Anyway the NRMA/RACV had it open in about 30 seconds. they have a rubber bladder that goes in behind the rear top corner of the drivers door and they inflate it with a hand pump to open a gap and then stick something down to pull on th door button. No damage to the car at all. If your not in a road service organisation either join then call them or pay them for a one off. It will be cheaper and easier than smashing your car and then having to fix it.
    Vk ls1 turbo
    Aug 2009
    townsville
    just smash the front windscreen
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
  15. #15
    Vk ls1 turbo
    Aug 2009
    townsville
    and the back one
    2002 HSV GTO COUPE
  16. #16
    1990 VN Executive
    Nov 2005
  17. #17
    VP Commodore wagon v6
    Jun 2010
    Moe, Victoria
    yeah RACV would get my vote. I'm not sure that telling people on a public forum how to break into a car and yet make it look legit is the smartest thing to do though?
  18. #18
    Dec 2009
    I locked myself out of my VN twice from memory. I don't think anyone would buy one to steal from cars they would just break into the car. I'd also think with the age of these cars now and a well worn drivers door lock you may even be able to use someone elses key?
    You can get them online; http://lockout-kits-things.co.cc/eas...without-damage
  19. #19
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    My vote is passenger side window, thats how i got into mine, $30 fix at wrecker, took 30min to change
    ________________________________________
  20. #20
    VP SS, Cammed VN V6 daily
    Jan 2010
    the easiest way to get into it would be what i have done a few times on my VN, even on VT's, i'm not a thief or anything but the missus is quite clumsy when it come to locking the keys in her car. I have an old buick v6 dipstick that i have bent to work with a tab on the end, all you do is pry the top corner of the drivers doors out with a flat screwy until you can get the dip stick in then saw back and fourth down until you are low enough to reach the lock, hook in the bent tab and pull back up. It take about 15secs after some practice and due to the dipsticks better strength compared to a coat hanger it will easily overcome central locking crap too. I keep it in the boot in case i see some1 at the shops struggling. PS please don't use this trick for Evil, Karma's a bitch and the evil dipstick gods will hunt you down
  21. #21
    VT V8 berlina
    Jan 2010
    Done this a few times myself and was shown by an raa member how to get back in without breaking any windows ,its that easy even my misses did it......get a coat hanger bend up one end go to your back door slid it down the glass into door with the bent side facing back ,,now slide it down and towards the back of your car and lift up it should grap hold of your door lock mech opening your door but not unlocking it??????its really easy
  22. #22
    vq rat's Avatar
    vq rat is offline vq rat
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    I work for the RACV drivers back door is the way to get in easy as pm me ya number and i can talk ya throw it, as putting it on here many be a no no and the mod's will delete it
  23. #23
    May 2010
    Croydon, Vic
    Got it open, Rang racv in the end, they quoted me 200 odd dollars, i was like wtf, it'd be cheaper to smash the window, Then told them im 19 and they changed it to $41 and signed me up for roadside assist, not too shabby
    But i watched how he opened it.. seems to be a pretty easy operation
  24. #24
    HJ premier
    Jun 2010
    packing strapping works the best the stuff they use on bricks just have to bend it the right way its really not too difficult
    took me about 5 min on my first try good luck with it mate
  25. #25
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    Easy way to do it at home. Ive done this before, Grab a door wedge and pry it in the top corner so you have a gap big enough for your finger to fit, grab a coat hanger and bend it out straight with a hook in the end then fish your keys out. When i did it they were in the ignition if there somewere else its a bit harder.
  1. help. Locked my keys in my car.
    By TWOJZ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-05-2008, 08:00 PM
  2. HELP!!! i locked my keys in the car!
    By Miss T in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2007, 08:57 AM
  3. I need help. Keys locked in car.
    By ~me~ in forum General
    Last Post: 27-11-2005, 09:05 AM
  4. Keys locked in car
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-11-2005, 04:47 PM
