Results 1 to 5 of 5
Thread: cruise control in 5 speed
    VN Berlina
    Aug 2007
    Carrum Downs
    Default cruise control in 5 speed
    hey guys.
    i have recently converted my vn berlina to a 5 speed.
    it has factory cruise control but ever since the conversion it doesn't work anymore.
    if anyone knows why this is or knows how to fix it advise would be much appreciated cheers
    VP Exec
    Jun 2005
    Disconnection of the brake pedal switch?
    If there isn't already, there should also be a switch put on the clutch pedal - and the cable (switch) adjustment checked periodically.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    YEah it would have to be the break switch not adjusted up properly i would say. Check its adjustment. Dont worry about one on the clutch, its simply annoying. Every time you push the clutch in the cruise cuts out. Real awsome when ya just trying to go back a gear up a hill.
    Reaper
    VN Berlina
    Aug 2007
    Carrum Downs
    cheers guys but i don't think there ever was a switch on the brake pedal the only thing that was really changed / unaccounted for was a wire that was previously connected to the auto in the same plug as the reverse light wires. i think from memory it was grey and red. its now connected to nothing and that was the only wiring change apart from bridging the reverse light wires which now stay on all the time.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Cruise will have a brake switch. VN will be brown wire and grey green.
    and 3 Dangerous non ABS VN's
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. Cruise Control Speed Signal
    By antelopeslr5000 in forum Electrical Wiring / Questions
    Last Post: 16-05-2009, 11:25 AM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. VR Cruise Control & Speed Alert
    By woza01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2007, 12:52 AM
  5. Speed Input Cruise Control
    By The1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2005, 05:46 PM
