Results 1 to 9 of 9
Thread: VS Trans into VN
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    Default VS Trans into VN
    Hi all, im i have a 89 VN Berlina S1 with a dead trans and i am able to buy a Complete VS that has been in a crash, im wondering can i use the VS auto in my VN or would i have to swap engines aswell, id rather keep the VN Motor if possible, both cars a V6 Auto's
    Thanks
    Greg
    Officially In The SunRoof Crew
    '05 VZ Berlina September '09 - April '11
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    no you cant just use the gear box there is a pretty big difference between the boxes
    92 VP Series 2
    Jan 2009
    East Brisbane
    yeah mate would be a MASSIVE job as vs has electronic gearbox and vn's dont. your ALOT better off just buying a second-hand vn or vp gearbox and swapping them
    Mar 2010
    Whyalla SA
    yea ok then i haven't actually got the wreck yet but i should be able to pick it up for about 500-600 with 209xxx on the clock so i was thinking it would be a good deal then selling the parts i dont use and then selling the body for scarp which is around $150 on its on at the moment so i should be be to make my money back on it
    Vt ss ls1 6spd /vp berlina 5spd 5ltr
    May 2010
    SA
    VP ute
    Mar 2006
    What's the big deal? You are getting the full wreck. Swap the wiring, engine and gear box.
    Mod the VS dash to suit or make a few adjustments for the speed alert unit to fit what you have. As long as you get the keys with the wreck you should be OK.
    Yeah it is a bit more than just swapping the gear box over though
    Mar 2010
    Whyalla SA
    Quote Originally Posted by Fu Manchu View Post
    Yea bit id rather stay with the buick motor tho, thinking i will probally just find a cheap working trans and get rid of it
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    trade the local wrecker the vs for what u want. but there is away to "short the Loom " on a vs box to run it in a vn etc. but you loose the trans auto lock up.
    Making and running DUAL CHIPPED ECU SINCE 2010
    Mar 2010
    Whyalla SA
    yea i decided to ive the vs idea a miss, dont really want it laying aroud lol, already too much here, so ive got a VN trans lined up for $100 so i reckon ill go that way then sell it on
  1. [NZ] l67 trans ecu and loom and subframe trade for 5l trans ecu,loom and subframe
    By Nzpure in forum Swap / Wanted to Buy / Trade
    Last Post: 21-04-2010, 09:51 AM
  2. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. Dec 97 VT Trans?
    By gwynmart in forum General
    Last Post: 22-05-2006, 02:18 PM
