Results 1 to 4 of 4
Thread: vp clutch problem
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Default vp clutch problem
    hey guys, just changed the clutch in my vp v6 yesterday and something doesnt feel right. my old clutch was a Exedy Heavy Duty and it was on its last legs so i decided i would change it before i was stranded in the middle of nowhere. i got a RPM heavy duty clutch this time around and also bought a new clutch cable. i fitted everything up but coming time to adjust the cable, ive wound the adjuster almost all the way out and the pedal doesnt sit where it used to. it infact sits lower than what it used to, but, it engages and disengages fine and selects gears fine too. the only other thing is that the clutch pedal vibrates a bit too but stops as soon as i rest my foot on the pedal. the spring on the clutch pedal is there and it fine before anyone asks. what could this be?
    thanx in advance
    George
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    You probably have a worn bearing retainer...the tube surface the throw out bearing runs along as you depress the clutch....I have the same problem...... because there is a worn area just at takeup point the throwout bearing moves around a bit at this critical point and this movement is transmitted along the cable to the pedal....I have got a reconditioned bearing retainer from mal wood ($110) and also a steel throwout bearing carrier for my t5 but I havent fitted it yet....pain in the arse to pull it out again especially when I have only just put it all back together after replacing the clutch.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Nov 2003
    northside brisbane
    Yes Mine was really bad before I changed the clutch...you could feel resistance as you pushed the clutch in and out and when I had a look at the throwout bearing the spline surface had worn off one side...I smoothed out the wear on the bearing retainer surface and was told mine wasnt bad so I put it back in...bum steer...took a little while but the vibration returned
  1. Clutch problem or not ???
    By mitchy_vn in forum General
    Last Post: 08-07-2010, 02:00 AM
  2. VX clutch problem
    By HottieVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-07-2010, 07:43 PM
  3. Clutch problem??
    By AngryVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2007, 06:11 PM
  4. help;clutch problem
    By ashzv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2006, 09:25 AM
  5. Clutch Problem
    By Andre's SS in forum General
    Last Post: 30-06-2006, 02:48 PM
