Results 1 to 3 of 3
Thread: Vn steering wheel nut threaded striped
    vn exc
    Apr 2009
    Default Vn steering wheel nut threaded striped
    Hi I had a good search but couldn't find anything
    Ok my vn has a sports wheel and it's not straight
    And I went to take it off and the threads stripped
    So the nut now I don't no wat to do
    Any ideas cheap fixes would be gr8 or do I need a whole
    New steering column
    Wayne
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The shaft will pull out of the steering knuckle - but it's very tight.
    When pulling a wheel off my VN some years ago I had to hit from behind with a hammer as it just would not let go. In the end asked a mechaninc what to so as I did not whish to smash anything. He was brutal in his attack on the wheel and go it off in about 30 seconds. (I'd been at it for an hour). After this I noticed it did not fit back on properly and the horn failed to work. The shaft had half come out and was not sitting into the coloum properly. Tapped it back down and all was good.
    So you can just replace the top half of the shaft with a good unit. But you may have to replace the complete unit tho - Wreckers are your freind
    and 3 Dangerous non ABS VN's
    vn exc
    Apr 2009
    ok thanks do u think its hard to change ???
    cheers
  1. how do i remove a threaded bolt?
    By impulsive in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2010, 07:44 PM
  2. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  3. bolt threaded help!!
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2009, 08:08 PM
  4. Cheap Vr Parts Complete Car To Be Striped Will Post Aus Wide
    By tunsa in forum Parts And Other Items For Sale
    Last Post: 10-01-2008, 10:36 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
