Page 1 of 3 123 LastLast
Results 1 to 25 of 58
Thread: Difference between 304 vn & vp engines
    HJ premier
    Jun 2010
    Default Difference between 304 vn & vp engines
    hey i was reading through a workshop manual and it states
    Vn Commodore : 168kw@4600; 400 Nm@3200
    Vp Commodore : 165kw@4400; 385 Nm@3600
    was wondering if anybody could give me a reason for the difference ?
    Vt ss ls1 6spd /vp berlina 5spd 5ltr
    May 2010
    SA
    ive got holdens owners manual for both vn and vp and it says there the same lol my vp 5 liters flogs my vn ss but thats probly because its manual lol
    con7502003 is offline Banned
    vn 5ltr
    Jun 2009
    warrnambool
    vn blocks are better than vp, vps bit thin in the walls guys have been pokin vn blocks out ta 396, wont last on vps keep splittin blocks, so if ya got a vn block can i have it pls
    VS Berlina 3.8
    Dec 2008
    Maybe, just maybe, it was because they took those readings from different points in the rev range?
    If anything, I doubt that there is any difference in the VN/VP blocks at all, and that this may even be a simple difference in tune.
    Jun 2005
    Quote Originally Posted by con7502003 View Post
    Where did you hear that BS? They're the same block.
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VP SS, Cammed VN V6 daily
    Jan 2010
    agreed, BS same block. I don't know why they are different in power but i can tell you right now that after 20 odd years its not that much anymore and i can make 3kw of power at the flywheel by breathing down the intake :P When i dynoed my VP SS when it was stock with an auto trans it had 135rwkw and 636Nm so factory quoted figures are BS too
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by agrsv8 View Post
    It is probably a different tune, and those factory figures are at the fly, not rwkw
    50LTRv8
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by 50LTRv8 View Post
    even tho it still equals 180kw atf so it woulda had some sort of tune, my vn got 125rwkw when was completely stock which is about 168kw atf
    "A life lived in fear is a life half lived"
    Jan 2010
    how do you figure that. 165kw-15% for driveline=140rkw maybe -5kw extra due to the auto trans and i'm spot on.
    Jun 2005
    How about some dynos just give out really high figures, especially the ones in SA? It may have said 135rwkw, but it was probably closer to 120
    Jan 2010
    thats a pretty broad point of view, i'd hate to see what you think of Sydneys Dynos, what about QLD or is the Dyno you use the best one. :P wateva
    Jun 2005
    Uhh no, I don't use dyno's because they're a stupid way of trying to compare two completely different cars, especially when the same dyno isn't used. A lot of people on this forum would agree with me about SA dynos, with plenty of SA V6's pulling stupid numbers like 160rwkw. Probably comes down to having no track to back up the numbers.
    vn 5ltr
    Jun 2009
    warrnambool
    Jun 2005
    same block my ass first vn v8 thicker in the bores fact.
    And you have proof of this? Would love to see it. Until then, BS
  15. #15
    VS Berlina 3.8
    Dec 2008
    Yeah, no.
    Not believing this until you can prove it. Also, what does "thicker bores" mean? If the bores were different, you would have to buy different pistons for VN and VP. Never seen that before.
  16. #16
    car
    Jul 2006
    greensy, melb
    lol where you get that calculation from? never heard that way b4, for years ive been using the 1.34 calculation, 135x1.34=180.9, same as the other way if you want to turn fwkw-rwkw, 180.9/1.34=135.
    that would have to be the closest calculation i have seen for working that out, have been using it for years and i have seen many other people will use that same one too so no, you are not spot on...
  17. #17
    VS Exec 5spd
    Aug 2008
    there is no calculation for fwkw to rwkw. it will be different for every car, even cars with the same engines n trans.
  18. #18
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by shifty6 View Post
    It's always been a guestimate (so yes, no exact calculation) percentage about how much the driveline anyway hasn't it? It's not really worth trying with cars that have stock engines that are nigh on 20 years old anyway.
  19. #19
    car
    Jul 2006
    greensy, melb
    like i said, it would have to be about the ''closest'' calculation
  20. #20
    Jan 2010
    pretty sure you are wrong there mate, what you are using is the HP-kw conversion.
    1.34 is for kw to HP ie 1.34Hp=1kw
    cheers for the LOL
    LOL
  21. #21
    VK V6
    Mar 2010
    NZ
    ^ Its common to equate kilowatts at the flywheel with the same number of horsepower at the rear wheels
  22. #22
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Someone has misread the info.
    VN-VR are 165
    VS are 168
    And this was just bolt on stuff, motor is the same.
    I had a read of the Aussie 5L book (which has all the specs for all the holdens 5Ls) and there was nothing of the sort about different blocks.....(wish i bought a copy so i could scan it in)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  23. #23
    May 2010
    SA
  24. #24
    car
    Jul 2006
    greensy, melb
    cheers for the LOL
    LOL
    rwhp and fwkw are close enough to being the same number so that why it does work lol
    if you want there is another calculation that works pretty close too, add a 3rd of your rwkw to achieve the fwkw, 135+45(1/3)=180
  25. #25
    vx gen111 wagon
    Jul 2009
    perth
    to much bloody maths for me put it on a track and give me a number
  1. difference between 07-08 sv6 engines
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2010, 11:46 AM
  2. DI Engines
    By Super Coach in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-08-2009, 08:54 PM
  3. Difference between L67 and L98 6.0L Engines
    By ChargedBT1 in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-07-2008, 05:19 PM
  4. Difference in Colour Engines?? VK
    By Frandy in forum General
    Last Post: 27-10-2006, 11:18 PM
  5. Whats the difference in all the V6 engines..???
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2005, 04:01 PM
