Results 1 to 6 of 6
Thread: SV5000i Statesman
    SV5000i
    Jul 2010
    Queensland
    Default SV5000i Statesman
    Hey all. Very new to forums so hopefully I've worked it out right. I have an SV5000i that has been parked up for a few years and now have some time to spend on it. Before I pour my heart and soul into it I wanted to get an idea of if it is a sort after model and where I can find out more about them. I'd also love to make sure it's all the real deal. The VIN numbers on the plate under the windscreen match up with HSV but I wouldn't know where to start looking for the numbers stamped into the bodywork. Any info would be greatly appreciated
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    Not too sure if im correct or if this helps but there should be a Body number stamped in under the driver's seat, if you slide it all the way back and lift up a small flap of carpet
    Officially In The SunRoof Crew
    '05 VZ Berlina September '09 - April '11
    SV5000i
    Jul 2010
    Queensland
    Unfortunately no joy. I had a look and found nothing visible. Nearly the entire floor is covered by a 5mm thick sound deadening medium. I would hope that the factory would leave a window in it around the numbers if they are here similarly to the clearance left around mounting bolt holes ect.
    Thanks for the suggestion tho.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    You should be able to find out quite a bit on wikipedia and the official holden site.
    Warranty Void
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The only "body" ID is under the left headlight. It's the body number tag "L123456" should match the last bit of your VIN under the screen.
    You may also find a build sheet under the carpet on the passengers side. (can slip back to the rear.)
    and 3 Dangerous non ABS VN's
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Dunno about "sort after" as such. It would be a desirable model for a neesh??spelling market. I wouldnt be spending a heap on it to try and sell it off at a profit. What you do to it will be for yourself and to make it what you want it to be.
    Reaper
  1. vq statesman with vs statesman front
    By Mazzone_Child in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2012, 02:39 PM
  2. SV5000i
    By farbs in forum General
    Last Post: 11-07-2010, 01:32 PM
  3. [VIC] FOR SALE: VS Statesman Parts. Inc Custom VS III Statesman Interior
    By xcesiv in forum Parts And Other Items For Sale
    Last Post: 01-06-2010, 04:37 PM
  4. Will VS statesman door fit on VQ statesman???
    By t-rav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2009, 09:40 PM
  5. [VIC] VS SII Statesman
    By jimmig81 in forum Vehicles For Sale
    Last Post: 20-09-2009, 04:42 PM
Tags for this Thread
