Results 1 to 8 of 8
Thread: central locking
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Question central locking
    hey guys i have a trackpro central locking kit its all conected but i dont have the flashing indicators when i lock the car the wire that does that needs 2 b conected but i have no idea how or were that cable is spose 2 go the instructions dont say how anybody done this b4??
    cheers
    dylanstone's Avatar
    dylanstone is offline tsu tsu tsu tsu
    3.8L 1997 VT executive
    Feb 2010
    sydney, eastern suburbs
    does anyone else have the problem in a VT where it only unlocks "sometimes"?, where you have to re press the lock and unlock button 4-5 times
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Quote Originally Posted by dylanstone View Post
    Search for my post on this, I don't want to type it all again.
    As above, door trims off (remove plugs covering screws in arm rest, screw under door handle, pop out lock inner orange bit, pop trim loose from bottom and once clippy things are loose push whole trim up out of window channel) and cut inner plastic shield over lock area on 3 sides, (big enough to get your hand in) peel it back undo 3 star drive screws from end of door (allen key works ok) unplug solenoidy thing, unclip linkage, remove lock assembly and clean all linkages and moving parts. Solenoidy thing attaches with a couple of screws, clean plug and connector with metho if they're dirty, plug solenoid in before reassembly and test. Sometimes this works real well, sometimes the solenoid man is tired and it's time for a trip to the wreckers. Unfortunately you may not be able to say which before it's been tested for a few weeks.... After a bit of practice it doesn't take more than 15-20 minutes per door. First door probably more like an hour. take the opportunity to clean window bottom where you can't usually reach and vac fuzzy trim edge that sits against window. Getting trims back on, push into window channel first, leave trim tilted out while you get clippy men lined up and start pushing in from top and line up lower down as you go. You'll have to lie on the ground looking up into the gap to line up the clips. have fun!
    Warranty Void
    dylanstone's Avatar
    Feb 2010
    thanks heaps, it only happens occasionally, i think ill just live with it looks like a big job
    Jan 2010
    that has nufin 2 do with wat im trying 2 get help with y do people start a diff subject in some1 elses post?!?!?
    anyway how do i conect up the flashing indicator lights wen i open or unlock the car??
    VN Wagon
    Feb 2005
    The aftermarket alarm I fitted needed the indicators to be wired into a relay output on the alarm unit.
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    couldnt u just find the hazard light fuse and wire to that -- fuse - wire something like that - that should make all lights pulse
    dylanstone's Avatar
    Feb 2010
    Quote Originally Posted by nudge701 View Post
    sorry bout that, my bad
  1. VZ Central Locking
    By Trevor 062 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-06-2009, 11:51 PM
  2. Central Locking
    By 95 VR_CALAIS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2009, 09:40 PM
  3. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  4. HELP!!! central locking!!
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2005, 09:30 PM
  5. central locking again..
    By warney in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 12:21 AM
