Results 1 to 14 of 14
Thread: Realllll bad economy! HELP? :)
    VP Calais V6
    Nov 2009
    Default Realllll bad economy! HELP? :)
    So my commodore is getting about 250 around town and 500k country driving.
    Thing is... I drive it real easy. People driving lead footed are getting more :S
    Car only has 60,000ks on it.
    Just got it and the original owner was an old guy.
    Car sat around for about half a year.
    I would think the o2 sensor is quite young, so it wouldnt be the problem.
    Any ideas would be appreciated.
    Thanks
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Check the error codes and see what comes up. If it sat around for a year and a half I would personally change leads, spark plugs and chuck some new oil in it.
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    +1 id give it new oil, oil filter, plugs leads and new airfilter maybe even run a few tanks of 98 with an injector cleaner
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    92 VP Series 2
    Jan 2009
    East Brisbane
    How young do you reckon the o2 sensor is? Cos anything over 30,000 kms and the o2 sensor can start deteriorating. I was getting about 17 litres per 100kms city driving and 10 litres per 100kms highway driving and when I changed the o2 sensor it went down to 13 litres city and 8 litres highway. Not saying its gonna be the problem in your case but definately dont rule it out ay. Good luck with it mate
    VT
    Apr 2005
    QLD
    Sounds like you need to give it a service then take it to an off-street drag meet.
    Flog the piss out of it.
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    Ive solved all my fuel economy issues by changing the O2 sensor, Fuel pressure reg, fuel filter and replacing all the breather lines on the fuel tank because they were totaly deteriorated. I get over 400km to the tank city driving (i just fill up around 400km have not tested it till empty)
    vs commodore
    Oct 2009
    Tamworth NSW
    I wouldnt rule out the oxygen sensor even if it has only done low km's.It might have corroded inside the pipe or it could just be a faulty one that is sending the wrong info to the ECU.. Id do the above mentioned full service on the engine,including the fuel and air filter, and also change the auto trans filter and fluid, if it is still bad on fuel after that,then Id be looking at replacing the oxygen sensor.Also try putting some injector cleaner in the fuel tank a few times when filling up..One more thing to check is for dragging brakes.The pad only has to touch the disc slightly if a caliper is seized up a bit and not retracting properly,and it will cause slight drag and increase fuel usage.
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    is 13 to 13.5 per 100k's around town bad economy for a series 2 vn v6 calais?
    VN Calais With All The Factory Fruit I Need!
    Feb 2010
    Quote Originally Posted by Brett_jjj View Post
    I wouldnt rule out the oxygen sensor even if it has only done low km's.It might have corroded inside the pipe or it could just be a faulty one that is sending the wrong info to the ECU..Id do the above mentioned full service on the engine,including the fuel and air filter, and also change the auto trans filter and fluid, if it is still bad on fuel after that,then Id be looking at replacing the oxygen sensor.Also try putting some injector cleaner in the fuel tank a few times when filling up..One more thing to check is for dragging brakes.The pad only has to touch the disc slightly if a caliper is seized up a bit and not retracting properly,and it will cause slight drag and increase fuel usage.
    how do you check for brake drag?
    vs commodore
    Oct 2009
    Tamworth NSW
    Just jack up each wheel and spin them by hand and take note how hard they are to turn,they should spin fairly easily with a bit of drag.If one is really hard to turn then it probably needs further inspection by removing the brake pads or caliper and then turn the wheel to see if it turns freely now.Remember the rear wheels will be turning the diff and tail shaft so will be a bit harder to turn.But you will definitely notice if one of the calipers is stuck on a bit.If you do find one is seized,then its best to replace or service the calipers as a pair,either both front calipers or both rear calipers .
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    also check typre pressure
    92 VP Series 2
    Jan 2009
    East Brisbane
    Quote Originally Posted by LordMayhem View Post
    lol a bit off the topic but yer thats quite good. my vp gets about 13.5 - 14 around town and my mates vn series 1 gets around the 14 - 14.5 (and considering your calais model is a heavier car than the standard executive model that makes your fuel economy even better)
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    cool thanks my o2 sensor must be ok then. was just wondering sorry for the hijack
    VP Calais V6
    Nov 2009
    Thanks for all the replies guys.
    I think I will get onto the o2 sensors first.
    Anyone know how many ohm I am looking for? Can it only be tested cold?
  1. vy economy on gas
    By steve40 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-10-2008, 09:41 AM
  2. 6L V8 Economy
    By Darren in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-10-2008, 05:24 PM
  3. VK EFI 6 Economy
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 11:42 PM
  4. SS Economy
    By xcaluber in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-10-2005, 10:23 AM
  5. Better economy?
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 01:27 PM
