Results 1 to 6 of 6
Thread: Diff Oil Change VP Berlina.
    VP Berlina
    Jul 2010
    Nowra
    Default Diff Oil Change VP Berlina.
    Can anyone please help/direct me to what i have to do to change the diff oil in my VP. What is the reccomended oil and what i need to do. If you are able to help it would be greatly appreciated.
    Cheers Reg.
    car
    Jul 2006
    greensy, melb
    if you have irs then you just undo the middle very bottom bolt to drain and about halfway up that backing you will see a bigger bolt near the centre for re-filling.
    if you have a live axle setup then the best way is to take the whole back off it to drain and replace with a new gasket and it has a rubber plug near the middle which you use for refilling.
    on both setup's you fill until the fluid is coming back out of the whole you are filling from.
    "A life lived in fear is a life half lived"
    VP Berlina
    Jul 2010
    Nowra
    thanks for your help Kniever it is greatly appreciated. Just a couple more things, how do i tell ff i have an IRS and what type of fluid do i use?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I have live axle but i dont take the back plate off, its way too much effort. Just buy a little hand pump from the auto shop and pump the oil out and then you use it the other way round to pump the new oil in. If you have a LSD be sure to use proper LSD oil which is slightly more expensive. You should find what oil it is in your owners manual.
    When you buy the oil its easier to just ask at the counter for the right oil, or if you go to somwhere like super crap you'll have to look up your model in one of their books they got hanging in the isles.
    This pic shows IRS on the left, notice the rubber boot on side of the diff housing. On the right is a solid axle setup.
    Note: These arnt commodore rear ends, for display purposes only
    Reaper
    VP Berlina
    Jul 2010
    Nowra
    VR Wagz you are a dead set legend! I have a solid axle set up on the VP. the IRS looks so much more complicated, thanks heaps for your time and patience. i new to the commodore maintence world. With the solid axle set up do i need to replace the gaskets and seals or can i just bleed it and refill?
    dirt drifter's Avatar
    dirt drifter is online now white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    just bleed and refill, the drain point is the very bottom backing plate bolt, the fill point is the rubber bung halfway up. if u cant find a hand pump to get the oil in what gets me out of trouble is....
    undo the panhard rod off the diff (the big bar running from car body to diff) pull it down to give yourself some room to work. then cut the top half off a 1.25L coke bottle and stick a hose in the end that is skinny enough to fit inside the diff's fill hole. this is your funnel. then using the bottom half of that coke bottle, put oil in it and tip down the funnel. go easy it will take a while to drain thru into the diff.
    i'm going to state the bleeding obvious here, this is way easier if its on a hoist. its definately doable if its on the ground jacked up on axle stands its just the whole holding the funnel, pouring the oil while lying under the car without covering yourself in oil part that isn't much fun. best of luck with it.
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
  1. Vy V6 Diff Change
    By richierich in forum V6 Development And Modification
    Last Post: 08-05-2010, 12:54 PM
  2. Diff change
    By Kernal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2009, 02:06 PM
  3. Change Diff from 3.27 to 3.45 or 3.7?
    By joshtaylor87 in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-06-2008, 11:28 PM
  4. Diff Oil Change
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2006, 06:20 PM
  5. diff oil change
    By oliver in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-02-2006, 03:10 PM
