Results 1 to 7 of 7
Thread: VN v8 trans playing fully games
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Default VN v8 trans playing fully games
    Had my v8 for about 6 months now... My first v8, and back to an auto (said i'd never do that again.. but anyway)
    When i bought it i made sure the trans was operating perfectly, and it did.
    til now.
    when i hold it flat the 1st to 2nd change is a bad slur, like it's slipping. But at 3/4 throttle it shifts fine and bumps into gear. even kick down is precise and doesn't slip.
    Only change since i bought it was i put in a VS 5L engine and got it dyno tuned. Makes a reasonable amount more power than it did stock, but not enough (I would think..) to cause the trans a premature death?
    Did a service today and it seems a tad better, still slips. Removed the trans cooler and the trans seems more responsive?? what the?
    Before people jump to it... Yes i have adjusted the kick down cable, and throttle cable correctly
    oh and the other thing i noticed after adjusting the kick down cable.. the gears shift through very early. Doesn't hold them very long???
    any other ideas on what is up with it??
    If this trans is dead in going manual
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    GTP 85's Avatar
    Aug 2006
    Opps, just realised i typed "fully games" instead of "FUNNY games" haha
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you sure you adjusted it correctly pull it right out of its slide and then go full throttle the TV cable will slide into the correct postion by itself
    GTP 85's Avatar
    Aug 2006
    That is indeed what i did!
    в∞ѕтεכ √&
    Jul 2008
    NZ
    give it an extra click or 2 max may help a little youll find the 2nd gear band is probably getting worn corvette servo may help
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Easy to adjust.As your looking at the adjustment press the button in and then slide the hole adjuster to the driverside guard.Then hop into car and with engine off depress the accelrator pedal to the floor it should adjust to where you have your foot planted on the accelerator pedal.And your ready for cruisin.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    GTP 85's Avatar
    Aug 2006
    thanks i'll try it that way, see what happens. Might have a manual bought by tomorrow anyway haha
  1. trans playing up
    By vsn8tr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2010, 08:36 PM
  2. t5 playing games with me!
    By CruizinVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2009, 06:45 PM
  3. ps3 console: playing ps2 games
    By Goon in forum The LAN Lounge
    Last Post: 14-11-2009, 10:39 PM
  4. VN auto trans playing up
    By alchupanibre in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2009, 10:43 PM
  5. speedo playing games
    By hsvtj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2008, 04:32 PM
