hi! i have a nice problem.. well i noticed my coolent was leaking from a short pipe that runs from the top of the water pump an goes to the inlet manifold (just under the PCV valve part).. so i unbolted one side of the alternator an lifted it up an then i removed that short hose an found that there was a hair line crack in that carban plastic part that goes into the frunt of the manifold witch the hose clamps on too.. i undone the bolt that holds the part inplace an triyed removeing it but it just broke away bit by bit, i got all the peices out an cleaned it up ready for a new one to go in, but i do not know what the part is called.. can anyone help me in what the name is for that part?
a photo might be helpful
bypass hose connection
i have a photo
+1 for bypass hose
thanx!
can you still buy that plastic part.. haw mutch will that be?
check with repco or burson i think kill kenny castings have a brass replacement part ?
i hope so! that will be beter then the plastic stuff they use
theres on at the back too...probably just as old and brittle ...might be worth doing it too
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
ahuh, repco/bursons/autobarn/sca should all have the brass version, get it... worth the money to know you will never have the piece of shit plastic break on you again having you to try and break it out with a screw driver.... e.g what i did lol
cool thanx guys.. but i went to the holden dealer today to order some parts like the plastic connector $ 6.00, connector o' ring $8.00, bye pass hose $8.00, low pressure hose $15.00, reservoir $98.00 an o' ring for reservoir $12.00... $147 sounds good with me.. but for me to go to repco or stuff like that to get the bras replacement connector, i must travle 100'ks OR more as i live in deepwater nsw an holden is only 20'ks out.. so i get the plastic crap just for now as my rego is nealy due.. after that when my vn is up an runing once again then ill go chasing for the bras connector, an yer i will do the back one as well, so thanx for reminding me about the back connector...
CHEERS
