Results 1 to 13 of 13
Thread: vn ss overheating
    Vt ss ls1 6spd /vp berlina 5spd 5ltr
    May 2010
    SA
    Default vn ss overheating
    my vn ss is overheating its got a fairly new radiator new 81 degree thermostat i flushed the radiator n fitted a a 16 inch thermo fan my mate said it could be a leaking inlet manifold it climbs right up near the H any ideas?
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    did u bleed the air out of the system and did you use decnt coolant or jsut water
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    1 electric thermo will struggle to cool it
    May 2010
    SA
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    16inch thermo will not cool it. It has been tried and failed many a time by various members on this forum and people i know. I have personally gone AU twin thermo's, They work awsomely but they are physically to big and difficult to fit.
    If you have any doubts take 5 min to fit your old clutch fan and you will prob find it will cool fine.
    Reaper
    May 2010
    SA
    VrWagz1's Avatar
    May 2008
    wollongong
    If the clutch fan didnt do it either then thats probably stuffed too. By all assumptions it seems you have checked everything to ensure the cooling system is fine. So i would say use a duel 12" thermo and that would keep it cool. If you wanna stuff about though the AU's are a gaunteed work but they require a bit of cutting to fit.
    Reaper
    kitted 3.8lt 5 speed T5 manual VN S2 Commodore
    Jul 2010
    N.S.W , Coffs Harbour
    it might be your radiator cap lossing pressure and it will stop pumping the water threw. thats what mine did
    May 2010
    SA
    lol i have just replaced that 2 weeks ago lol the old 1 the top came of n left the rest stuck in the radiator lol
    VrWagz1's Avatar
    May 2008
    wollongong
    AU thermos not that good of a fit
    Heres a thread on the au's i did a while ago. How the bloke on the second page recon's he installed these on 30min i'll never know. Took me that long to cut all the old nobs and mounting points of the fan, let alone start to do any meausurements, marking, moving battery and charcoal canister.
    Reaper
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    The first thing to do is definitely to bleed the system properly. Turn the heater onto full hot, leave the cap off the radiator, make sure the overflow bottle is up to the line and run the motor for 10 min while squeezing rad hose top and bottom until there has been no air bubbles coming out of rad for a few minutes. As far as cooling fans go either use the original and the shroud or make a new shroud to take the electric fans or use ford mondeo twin fans from the wreckers. The original fan and shroud should work perfectly well, you probably swapped out problems when you installed the new rad and lost the original fan and shroud. Must have shroud for coolingness.
    Warranty Void
    May 2010
    SA
    all i did was take off the clutch fan n wire up the thermo the original shroud is still in place im gunna go with the twins n see if that helps oh and bleed the system
    May 2010
    SA
    hey lads i put the clutch fan back on and its still overheating and have orderd a new 1 also was wondering if advanced timing would that make it heat up more? if so how do you put the car in diagnostics mode to retard it?
    10 liters of aussie v8 cant go wrong
  1. overheating..
    By lumina01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2010, 04:07 AM
  2. Air Con and Almost Overheating
    By Feral01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2010, 04:03 AM
  3. How do i fix my car from overheating?
    By Inkar in forum General
    Last Post: 18-06-2010, 11:32 PM
  4. overheating with ac on
    By international95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2009, 11:12 AM
  5. Overheating....
    By SHANBANGER in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2009, 08:17 PM
