Results 1 to 2 of 2
Thread: difference between v6 and v8 vn tacho
    VNSS
    May 2005
    Default difference between v6 and v8 vn tacho
    gday guys,i have a vn ss and wondering what happens to the tacho if i put a v6 cluster in it,how does the tacho react? Does it work at all or not responsive?. REason i ask is i have tried 4 different v8 clusters and i cannot get the tacho to be responsive like it should be.
    Like when the car changes gear the tacho doesnt even dip at all and like it is in delay or something. My vn v6 calais the tacho moves with every lil touch of the peddle.,Or is there anything else electrical that can cause this problem that i can look at!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If you swap to VR gauges (V8) you will most probably fix the problem.
    V6 tacho will read high - thats all. Test it to see if it moves freely like when it's in the v6 car.
    and 3 Dangerous non ABS VN's
  1. VT - VX difference??
    By Craig54 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2009, 05:49 PM
  2. hsv tacho into berlina 5.7L standard tacho
    By genaero20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 04:08 PM
  3. difference between 304 & 308
    By vs5lute in forum V8 Development and Modification
    Last Post: 27-07-2009, 10:34 PM
  4. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  5. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
