Results 1 to 7 of 7
Thread: vn misfire problems
    vn commy
    Jul 2010
    nz
    Default vn misfire problems
    the other day i brought a vn commy and then on my way to work two days ago it started misfiring the charge light came on so i parked it up got chatting to a friend who said it might be the alternator so i check that it was running at 11.7 volts when i should be 12-12.5 so i got a new one and its still misfiring but its now charging to over 16 volts anyone got any ideas?
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    did you get a new one or just a second hand one? check all your conections and leads make sure that all the earth conections and leads are good
    VN Calais With All The Factory Fruit I Need!
    vn commy
    Jul 2010
    nz
    yeah i pulled it out and took it to the machanic he said it was sweet so i put it back in and it now sits at 14.1 but its still mifiring i found which cylinder was missing and its not sparking at all
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    that would be down to spark plugs/leads or coil pack/DFI module then mate
    92 VP Series 2
    Jan 2009
    East Brisbane
    a non-sparking plug could be a few things. could be the spark plug itself, could be a spark lead, could be a coil pack, could be the dfi module, could be the ecu, could even just be that a lead or some wiring has come loose. if you've got a multimeter at home test the lead and the coil pack associated with the particular cylinder thats not sparking up, thats where i'd start. good luck mate
    92 VP Series 2
    Jan 2009
    East Brisbane
    vn commy
    Jul 2010
    nz
    cheers for the advice
  1. V6 misfire - where to next?
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2010, 04:34 PM
  2. LS1 Misfire
    By G4orce in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-03-2010, 05:34 PM
  3. VN misfire
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2009, 08:49 AM
  4. vt misfire
    By linc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2005, 11:57 AM
  5. Misfire: likely causes?
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2004, 11:37 PM
