Results 1 to 11 of 11
Thread: engine swap?????
    VN Berlina 5ltr
    Jul 2010
    Post engine swap?????
    hi forum, i am just wondering! i am swapping my engines over. I am putting in a VS V8 into my VN V8, is this just a straight engine swap?? or must i change the looms? some input would be much appreciated.
    vp calais, vs ute, bmx, rc ae86 drift car
    Jul 2009
    croydon, vic
    pretty sure its a straight swap may to get the memcal recalibrated. what i would do though in ur case is strip the vs 5ltr down and rebuild it with new parts and cause the vs block came factory cleared drop a 355 stroker crank and rods and what not in there little head work valves springs retainers mild cam to suit get tuned and ull have a monster of a motor
    WTB: VY/VZ front buckets any spec
    WTB: VR/VS right hand side doors preferably white with electric motors for windows and locks
    VN Berlina 5ltr
    Jul 2010
    thanks mate, thats all i wanted to hear! heart stopped racing lol! as for a rebuild! i am thinking of rebuilding my spare 5ltr, only to suit a turbo setup. for just the engine swap is needed.
    Holden HG Prem / VP commo
    Jul 2010
    brisbane
    vpcal, hey mate, just wondering, i just pulled out a Vp 5.0litre, outta my vp and putting it in my hg prem,
    does the vp5.0litre come factory cleared for a 355 stroker? if not whats the best combo i should fit the engine out with? aprox 2 grand
    thanks guys
    Jul 2009
    croydon, vic
    the vp is not factory cleared only from vr onwards obviously for the gts and senator with the 215i engine (factory 5.7 stroker). im not sure what you mean by best combo to fit the engine out with but if i was in ur situation is either save a bit more to the stroker (complete eagle 355 stroker kit is only $1499 i think) and send the block and stoker kit away to get cleared balanced and cleaned alternatively get and acl race rebuild kit, crow cams cam and chip package, double valve springs from a ls1 slightly oversized valves and study a few manuals and have a crack at building the new engine myself cheers
    dave
    VN Berlina 5ltr
    Jul 2010
    another question, since i am dropping a vs engine into my vn (straight swap) do i need to change the dizzy from my vn engine(spark plugs etc..) to suit or am i able to leave it as it is and use either parts.
    Jul 2009
    croydon, vic
    because your using the original computer i assume the spark map wouldnt be any different. its the ecu that sends the signals to spark which cylinders. im not 100% sure but they should be exactly the same
    VN Berlina 5ltr
    Jul 2010
    ok seem simple enough, so l've looked at the plug on my loom and the plug on my dizzy and they are different. so l'm thinking i have to change them. reason being is with the time frame i have i cannot sauce a change over plug. so if it is just a straight swap as you are saying, then changing the dizzy from my oringal engine to the new engine wouldn't be a problem. correct me if l'm wrong. also if i spray some wd-40 on the flywheel nuts, will that make them easier to remove. engine going in this weekend. will keep you guys updated on progress.
    Jul 2009
    croydon, vic
    got it one id say
    VP Berlina LX wagon 5.0L M5
    Dec 2005
    for the flywheel nuts, yeah you could spray wd40. i dont think i needed to. just shove a screw driver or something through a hole in the flywheel against part of the block casting to stop the engine turning over. they are supposed to be torque'd up to 88nm from factory.
    VN Berlina 5ltr
    Jul 2010
    well i got the engine in lol, run awesomely mint to be honest! then but then after i put all the fulids and oils in! start her up tuned her up! but then wait for it! when to take the first test drive! BAM!!!! auto was smashed so i sent it to the auto shop and will be picking it up 2morow. should be a good weekend good times.
  1. VN > VT engine swap
    By stuee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2009, 01:59 PM
  2. vr engine swap into vs
    By melawramenko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2008, 08:08 PM
  3. vn-vt engine swap
    By jessiepal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 07:59 AM
  4. vn engine swap
    By blueholden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 03:33 PM
  5. Engine swap?
    By Piccolo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-01-2006, 10:55 PM
