Results 1 to 5 of 5
Thread: Fat Coolant Leak!
    VN II Berlina
    Apr 2009
    Default Fat Coolant Leak!
    Have a coolant leak, a big one at that, on my VP motor.
    Ignore the small splash on the right of the first photo, i found where that leak was coming from, but as for that huge pool sitting there, i have no idea! found it there this morning and I'm 99% sure its not from he same leak which is causing the small splash on the right, because i park it in the same spot.
    If you wanted to know anyway the small spot on the right is leaking from the bottom hose, just musnt be tight enough or might need some new pipe.
    Anyone got any ideas what it might be?
    i tried to get a few angles so you might be able to see where it would come from.
    thanks
    Attached Thumbnails Attached Thumbnails Fat Coolant Leak!-26072010-001-.jpg   Fat Coolant Leak!-26072010-004-.jpg   Fat Coolant Leak!-26072010-002-.jpg   Fat Coolant Leak!-26072010-005-.jpg   Fat Coolant Leak!-26072010.jpg   Fat Coolant Leak!-26072010-003-.jpg
    VN II Berlina
    Apr 2009
    EDIT: sorry about the poor quality photos, i took some great ones with a camera but it wouldn't let me upload them
    VN II Berlina
    Apr 2009
    anyone?? its really costin me a fair bit the reservoir tank is empty and more so about every 3 weeks
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    need some more info dude??
    does it over heat? how often do you have to fill it up?
    i am thinking water pump from where that water is sitting,could even be the bottles on the radiator have a good look and listen you should be able to find it mate jack it up and run it.
    My VL Walkinshaw replica project
    VN II Berlina
    Apr 2009
    Quote Originally Posted by *uwishn* View Post
    nah it doesnt over heat, underheats in fact.
    today was the first time it got upto the 3rd bar, highest it used to get was 2nd.
    about every 3 weeks give or take the reservoir tank is empty.
    il hava look at wat u said on the weekend if im not too dead from my operation!
  1. VT Coolant leak....
    By jwoods997 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2010, 03:02 AM
  2. coolant leak WTF??
    By wildwabbit in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2010, 06:55 PM
  3. coolant leak
    By scasacasa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2009, 01:38 AM
  4. coolant leak
    By burnsy150 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 09:39 PM
  5. Coolant Leak
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2006, 05:23 PM
