Results 1 to 7 of 7
Thread: vp calais leaking boot
    1992 vp calais
    Mar 2010
    Default vp calais leaking boot
    my tail lights just frkn leak no matter what i do ive siliconed them ive resealed them dont know what else to do i drilled a hole in the bottom of em makes no difference its a frkn pain cause my tailight looms are frked and holden dont make em anymore for vp calais
    any suggestions ? plzzzz
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Good luck dude I had the same problem with my VP Calais couldn't stop it and the boot leaked as well ended up with mouldy carpet and rust problems as well, finally got rid of the car and still leaked!
    1992 vp calais
    Mar 2010
    yeahhh its such a nice car i dunn wana sell it buhh its frkn frked soo yeah mite consider gettin rid of her interested ? lol
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    your positive its coming from the tail lights. put a hose on the top of the car, let it just flow out slowly and just sit and wait for it to start leaking in, if you can pinpoint the exact part where its coming in you should be able to fix it. thats what i did.
    The Black Beauty
    Jan 2007
    look at the rear quarter windows they also leak into the boot on vn -vs's
    get someone with a hose outside. u in the boot with torch and no boot carpet go looking for leaks
    Dec 2009
    Drill at least 3 holes in the bottom of each lens say 3/16 to 1/4 inch. Looms you can splice good sockets on use solder and heat shrink for a good job. Leak in boot will be the rear quarters they ar enot sealed well you need to take them out, clean the opening and windows up and seal with a non hardening window sealant or similar, don't use urathane as it will glue them in for good.
    1992 vp calais
    Mar 2010
    yeah did that mate got my cuzin in the boot and me with the hose and its 100% tail light seals buhh i siliconed em buhh made it worse anyone have an idea were i can get seals from
  1. 97 Calais vs 3.6 boot leaking
    By MikePee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2010, 05:31 PM
  2. vn calais. leaking boot.
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2009, 10:30 PM
  3. leaking boot
    By Muzz-VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2008, 10:22 PM
  4. boot leaking
    By ad45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 04:40 PM
  5. Boot Leaking
    By Lozzza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2006, 09:30 PM
