My VN will turn over then will only run for about 1 - 2 seconds then stops. I'm not a mechanic, so i have no idea what to do. I'm guessing it's not electronics, any ideas.
try doing a code check -
Checking your Computer for Faults (VN - VP)
fuel pump?
kick the tank and listen for the fuel pump common problem for them to die
i had the same prob witrh my vn calais just 2 days ago, start then die straight away, checked all connections and leads,hrmm bugger this went and got 10ltrs of petrol and waalaaa, all good,my trip computer was telling me porkies..
Found the problem. The fuel pump has died. Bugger. Thanks for the help.
Get the Ignition Coils checked. Sounds like they are on their way out. A very common VN problem.
