Results 1 to 9 of 9
Thread: trouble starting VNSS when warm!!!
    VNSS
    May 2005
    Default trouble starting VNSS when warm!!!
    Gday fellas, just having a pain in the ass problem with my SS, when starting car cold it seems to fire up ok,but if i drive 10mins down the road and turn it off and go into a shop i seem to have trouble starting it when its warm. It cranks but really struggles then will crank that slow it wont start. Then i turn ignition off for a min and then try again it will just crank over enough to start!!! Im thinking 3 things, 1 battery 2 coil and 3 starter... anybody else have this prob? Just seems when motor is hot it really struggles to crank.
    VP Calais 5 Litre V8 - FOR SALE!!!
    Nov 2009
    I have the exact same problem in my calais, it has a new coil and the battery is fine, starter im not sure on. first fire up in the morning turns over easily, starting when warm it struggles
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i'd say starter motor, i had a hq that did this many years ago. once the starter got hot it didn't like winding over, gave it a rebuild and it worked fine after that. it wouldn't hurt to check the condition of ya battery leads while you're at it
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VN Exec
    Jan 2010
    Im having the oppisite problem with my vn commy v6 its duel fuel and once first started each day it has to take a few goes id say two or three n u gota keep revs up then it will idle
    After that its fine for the day
    Any suggestions
    Im getting MSD coils when i get the $
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Just fitted a new starter motor to my VN V8 as it was getting slower and slower on the hot start.
    Boy does it spin over now I used the same battery, coil and wires and will see how it goes over the comming days. Look to have solved the lazy cranking tho.
    and 3 Dangerous non ABS VN's
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    My VS does it too, when it's warm takes a while to crank over. Cold starts perfectly though
    VNSS
    May 2005
    88GreenVN's Avatar
    Jun 2006
    The unit fitted to my V8 was just said to be a "new lite weight" unit. Works great as you would expect being new. Sounds very different tho. no more heavy grinding when you hit the start button
    I'll see if I can find out the brand name today.....
    88GreenVN's Avatar
    Jun 2006
    The starter motor fitted to my car was a:
    Bosch VS Hi Torque
  1. 304 Car not starting when warm
    By stocky in forum V8 Development and Modification
    Last Post: 29-11-2009, 08:58 AM
  2. VR 304 not starting when warm
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2009, 11:16 AM
  3. warm start trouble
    By reardo_202 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2007, 02:14 PM
  4. trouble starting when warm
    By mon_dave_vl_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2007, 12:44 PM
  5. Mates VN Not starting when warm
    By bsbozzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2006, 09:54 AM
