Results 1 to 4 of 4
Thread: Changing VN Gas to Petrol??
    Ando227's Avatar
    Ando227 is offline Serious?
    Vy Series II Ute
    Nov 2008
    Lightning Ridge
    Default Changing VN Gas to Petrol??
    So I'm thinking about doing some work to my VN Calais now that I'm driving a VZ around. First thing I want to do to it is remove the LPG from it..
    I've had it quoted for between $300 and $500.. Would like some idea's and thoughts on it.
    cheers
    VP Berlina
    Aug 2010
    vic
    It all depends on the LPG system thats in. Some of 'em are crap, but if it is a good quality system, like the kind my mate has (he plugs in his laptop and it fixes in ratio probs, there's no loss of power ext.) than I'd keep it, petrol's too expensive, my vp's a guzzler, but it's ultimately your choice.
    Ando227's Avatar
    Vy Series II Ute
    Nov 2008
    Lightning Ridge
    Thanks for ur view on it.. I wish I could just plug the laptop into it and have it fix the ratios up for me, but no. I've had a mechanic do the safety check on it for me, due to the mechanic that installed it had his licence suspended due to his dodgy installs, I nearly had to pay to frieght it to sydney for a real check over.
    I might have a mechanic friend that can do it here for me for cheaper. Ultimately, I would like to see it out of the car.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    It should be easy, you can remove all the components under the bonnet.
    Just cut off the supply at the tank, run the car on gas until it stalls, then start taking off the mixer, converter and fixing the water lines it taps into and your should be fine, then drive it to somewhere on petrol and get them to take the tank out
  1. changing from petrol to gas - stalling!
    By Jay09 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-04-2009, 05:05 PM
  2. E85 petrol.........
    By Daniel.B in forum General
    Last Post: 13-03-2009, 05:40 PM
  3. Which is the best petrol
    By commsirac in forum The Pub
    Last Post: 20-02-2008, 05:35 AM
  4. Petrol
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2006, 06:10 PM
Tags for this Thread
