Results 1 to 4 of 4
Thread: Vn Steering wheel not right?
    VR Exec II
    Sep 2007
    Question Vn Steering wheel not right?
    Hey everyone
    I just brought myself a cheap vn and have noticed the aftermarket steering wheel and boss kit doesn't line up straight witht he dash when the wheels are pointing straight. The car drives rather well with no unusual noises coming from the front end, Steering also seems fine so im thinking the wheel has been put on wrong? Anyone else have this problem?
    -Josh
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    yea i would say the steering wheel has been put on wrong when the wheels are straight and the steering wheel is off centered.
    undo the Allen key bolts straighten the wheel put the bolts back in pretty easy job.
    My VL Walkinshaw replica project
    92 VP Series 2
    Jan 2009
    East Brisbane
    yeah mate as said above ^ try that. if the steering wheel is only very slightly off centre though then that method may not work as there is so much gap between each hole. if it is off-centre by only a very small amount than you what you need to do is make sure your wheels are facing 100% forward (the longer your driveway the easier to do) then turn the car off and turn the steering wheel slightly until it clicks into that thing it does when the steering wheel locks up. then take the steering wheel off and undo the large nut inside the boss kit (usually about an 18 or 19mm nut off the top of my head i think? now get the boss kit out (you may need some sort of steering wheel puller or even a harmonic balancer puller to get this off). there should be a small marking like an arrow or a circle or something on the front of the boss kit somewhere, reinstall the boss kit with the arrow/circle at the very top, put it all back together and have a quick drive and see how much better-centered the wheel is and perhaps go back and try the whole process again to get it that little bit more centered if you need to. good luck with it
    VR Exec II
    Sep 2007
    Great Advice here Thanxs Alot =)
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  3. Adjusting the angle steering wheel / steering column
    By Kabooooom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2010, 05:12 PM
  4. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
